Community
Unexpected badger d...
Unexpected badger death
Just home from the pub. On the way back there were a pair of dead badgers in the road. Some what stiff so I guess they had been dead a while. No visible signs of dead or blood leakage.
Why would two dead badgers be in the road. Don’t we shoot them these days?
I’ve tidied them up. When I got home the electric had tripped upstairs. Is it a sign?
Posted : 14/01/2023 12:24 am
https://what3words.com/unexpectedly.badger.depth
Posted : 14/01/2023 12:30 am
How do you tidy up a pair of dead badgers?
Posted : 14/01/2023 12:36 am
Well mostly by gently hoofing them to the roadside to as not cause a diversion.
Posted : 14/01/2023 12:37 am
Ideal slipper sized pelts 🙂
Posted : 14/01/2023 12:38 am
Trapped, gassed then bodies left on road to get hit by a car to make it look like roadkill?
Posted : 14/01/2023 12:41 am
Roadkill badgers are fairly common though. Hit by a car you'd sometimes never even spot the damage unless you looked closely. Seeing two at the same spot? Could be that one was hit and the other went over to have a look.
Posted : 14/01/2023 12:44 am
Rubber necking bastards
Posted : 14/01/2023 12:48 am
Mebbe. It’s a single lane to nowhere. If you trapped and gassed them then you’ve missed countless acres of non roadside areas to dump a body.
Wondered about TB…
Posted : 14/01/2023 12:49 am
Two Badgers?
Posted : 14/01/2023 12:51 am
Why the need to make it look like an accident?
Are badger deaths investigated if they look suspicious?
Posted : 14/01/2023 12:55 am
Wondered about TB…
You think they might have both died of TB at the same place away from their setts?
Posted : 14/01/2023 12:59 am
Loved the first album
Posted : 14/01/2023 1:04 am
Double vision on the way home from the pub. There was only one.
Posted : 14/01/2023 8:52 am
Went downhill after the death of the two founding members imo
Posted : 14/01/2023 9:06 am
Meles and meles 🤔
Posted : 14/01/2023 9:10 am
Most forces have a Wildlife Crimes officer. They probably have a CSI (Badger) on call
Posted : 14/01/2023 9:21 am
Unexpected Badger Death was The Fall's second worst album.
Posted : 14/01/2023 9:23 am
An actual Badger who's trained to conduct investigations? That is a show I would definitely watch.
He's sullen and insular (he is a badger) but peerless in his field, has a difficult relationship with authority but gets the job done the chief respects him but most of their conversations end in shouting and a slammed door. Probably needs more backstory, he's had to move out of the set his wife hasn't stopped loving him but is so frustrated that he neglects his family for his work, and then there's his drinking.
I think I'd prefer a Badger detective to a Badger CSI, with a Geordie accent, prone to swearing and creative put-downs...
Call Netflix, we've got our Pitch!
Posted : 14/01/2023 10:34 am
Roadkill badgers are fairly common though. Hit by a car you’d sometimes never even spot the damage unless you looked closely. Seeing two at the same spot? Could be that one was hit and the other went over to have a look.
Like the hedgehogs in the Animals of Farthing Wood?
Badgers are double hard bastards, as Scotroutes says the damage may not be obvious.
Posted : 14/01/2023 10:37 am
You don't dispose of them on your own land because you then end up with bits of dead stinky possibly-TB-ridden badger scattered across your fields, but if you dump them at the side of the road the council comes along and gets rid of the corpse.
Posted : 14/01/2023 10:40 am
LOL @ hoofed to the roadside.
Must be a day for it, I had to swerve the car on my commute this morning to avoid a large dead badger. As I passed I wondered if I had hit it would it impede progress. 🤔
Posted : 14/01/2023 10:50 am
No they'll still build an estate of stupidly expensive houses with two "affordable" plots so they can get planning permission
Posted : 14/01/2023 10:59 am
I recently saw a dead badger that had been hit by a car. There were bits of plastic bodywork around the scene. Which does beggar the question of why so many "hit" badgers have no bits of car strewn around them.
Councils don't lift them from the road side.
Posted : 14/01/2023 11:07 am
why so many “hit” badgers have no bits of car strewn around them
and die neatly right in the gutter, too.  I think there's a suicide cult round here
Posted : 14/01/2023 11:13 am
 pk13
Toad and ratty are devastated about the news.
Posted : 14/01/2023 11:15 am
you see, for all the arguing, and echo chambering, this is why I keep coming back.
Posted : 14/01/2023 11:25 am
It was the snake wot did it
Posted : 14/01/2023 11:30 am
Sounds like a case for Captain Beaky and his band.
Posted : 14/01/2023 11:44 am
What tyres for running over a badger?
Posted : 14/01/2023 11:53 am
Something with a solid central stripe.
Posted : 14/01/2023 12:31 pm
"Councils don't lift them from the roadside" Yes they do. Highways Agency and Councils will remove road kill carcasses for driver safety. Otherwise you would see far more decaying carcasses, bone and hide, for months. Saw them regularly on our commute in rural Cambridgeshire (badger, deer, fox, hares). Your local Coucil will also remove any dead animal for health / disease reasons. Usually they have a reporting tool, e.g. report a dead animal
Back to the OP. two in the same place is most likely road kill.
Posted : 14/01/2023 12:39 pm
Old neighbor of mine was an old school estate management chap. He would definitely echo the above views of badgers trapped and killed and then dumped by the roadside under cover of darkness to avoid any questions concerning animal welfare. Wild animals, that could not be commercialised, living on the land were viewed as an inconvenience.
Cycled past a handful of individual dead badgers up in the South Downs lanes over the last five years, serious stench, should be tested as a cure for no smell after Covid!
Posted : 14/01/2023 12:59 pm
My word association for the title was: "In the bagging area".
Posted : 14/01/2023 1:04 pm
Did any of the deaths appear unexplained or suspicious?
Cookeaa
He'd have a young, streetwise fast talking vixen sidekick who he openly loathes, but deep down he knows she's excellent and wants her to take over the reins when retires.
Posted : 14/01/2023 1:13 pm
They probably fell into a pothole in the dark.
Posted : 14/01/2023 3:09 pm
 pk13
https://www.bbc.co.uk/news/uk-scotland-glasgow-west-64274298
Something is afoot/underbelly could be retaliation hit?
Posted : 14/01/2023 3:32 pm
With the stench, I don't hang around to check, rotting badger in middle of summer is vile!
Posted : 14/01/2023 3:40 pm
Evolution hasn't been kind to badgers especially when such a shy animal's camouflage is only effective when lying in the middle of the road.
Posted : 14/01/2023 3:46 pm
I'm pretty sceptical that people killing badgers then dumping them on the road to hide their crimes is widespread. I'm not saying it's never happened but I doubt it's common. I don't doubt that farmers (and others) illegally kill them, but I strongly suspect they leave them to quietly rot in a fox earth, woodland undergrowth or slurry pit rather than go to the effort and risk of moving them to a public place (roadside) where a. They might be seen and b. It would be pretty easy to establish they'd been killed illegally and not by a vehicle.
The reason there is badger roadkill everywhere is that there are LOTS of them (UK population doubled since the 1980s) and their road sense isn't great. Where I live in rural South Shropshire I can almost guarantee I'll see 2 or 3 shuffling across the road if I drive anywhere after dark on the narrow lanes by me. Both me and Mrs Bloke have (much to our distress) accidentally killed one when they've run out in front of us.  We are lucky to have a huge population of red kites round here and I reckon their diet is 80% roadkill badger.
Posted : 14/01/2023 3:47 pm
From personal experience Continental Double Fighters will roll over a Badgers head just fine.
After that I purchased some lights so I could see where I was going.
Posted : 14/01/2023 4:37 pm
