Ultra tedious WWSTW...
[Closed] Ultra tedious WWSTWD: Sidelights only in a streetlit 20mph?
I thought I was being courteous by switching the headlights off and going sidelights only once I get into the sidestreets. Pretty sure highway code backs me up on it too, so why do I get so many people flashing their lights at me? Do they want to be dazzled every time I hit a pothole or speedbump?
Posted : 27/11/2018 8:41 am
My traffic cop stepdad always told me it was fine.
Posted : 27/11/2018 8:47 am
I’ve never heard of this before - I can see the logic but I’m not surprised you get flashed.
Posted : 27/11/2018 8:53 am
it's perfectly legal to use sidelights at night in a 20 or 30 mph limit where streetlights are on. I prefer to be more obvious, but there are arguments (particularly with respect to cycle safety) against making cars that obvious (i.e. people end up looking for a pair of bright lights and won't see a perfectly legal bike light as they don't look carefully enough).
People flash at you because they are self righteous ill informed idiots, the same as any time they flash you.
Posted : 27/11/2018 8:54 am
Must be that they're probably recalling rule 115:
"You should also
  • use dipped headlights, or dim-dip if fitted, at night in built-up areas and in dull daytime weather, to ensure that you can be seen"
I'd flash to be honest, as sidelights at night would give the impression the oncoming driver was a bit unaware of the environment (elderly/confused), and therefore unaware of traffic around them. I'd want them to know other cars are nearby.
The worse one, however,  is sidelights with fogs when it's clearly not foggy. Just plain stoopid! 🙄
dipped headlights always for me.
HOwever according to the code its OK
  • ensure all sidelights and rear registration plate lights are lit between sunset and sunrise
  • use headlights at night, except on a road which has lit street lighting. These roads are generally restricted to a speed limit of 30 mph (48 km/h) unless otherwise specified
I am suprised at this - I thought it was dipped headlights when moving and sidelights were only for when stopped.
<h3 id="rule115">Rule 115</h3>
You should also
So the law is sidelights at a minimum - the advice is dipped headlights
Posted : 27/11/2018 8:56 am
 P20
DRLs probably add to the confusion. They may assume you only have front DRLs on and no rear lights.
I’d use dipped beam regardless tbh
Posted : 27/11/2018 8:57 am
If you hit a baby robin at night and it turned out you were on sidelights it might mean there were more questions to answer as to whether you could see effectively.
There's a lot of shadows between widely spaced street lights round here.
Surely the single track standard issue Audi has automatic lights. Put on auto, leave on auto. Problem solved :).
Posted : 27/11/2018 9:01 am
But surely when you're drifting round the corner with full oppo then you need all the lights you can get so the other road users know to make way.  Especially if you've foolishly put the new tyres on the back, because it'll take a lot of concentration to get the back out safely.  Anything less than dipped headlights and at least 4 Cibié driving lamps if it's even a bit cloudy is asking for trouble.
Etc.
Posted : 27/11/2018 9:10 am
It would be better if everybody did it but that will never happen so the reality is its probably best to go with flow.
Posted : 27/11/2018 9:11 am
This is would be my assumption these days - and tend to be what’s happening every time I see it
Posted : 27/11/2018 9:12 am
It's legal but people will think you've forgotten to put your lights on/being a numpty. It's a stupid rule IMHO, if it's dark just put your (proper) lights on. The other problem with sidelights is that they generally illuminate the dash, so some people then venture on to faster roads whilst still only having crappy side lights on and not realising...
Automatic headlights - it's the way forward 😉
Posted : 27/11/2018 9:16 am
Why do car manufacturers make DRLs that only come on at front and illuminate dash?
So many cars around here at the moment with no rear lights on, manly Vauxhauls, at dusk/wet/dark.
Posted : 27/11/2018 9:19 am
OP was too harsh on themselves - not tedious at all but interesting in a ‘christmas conversation with father in law’ sort of way...
Posted : 27/11/2018 9:22 am
I’m always amazed how cars can drive at high speeds on motorways when rains beating down with an inch of surface water and spray .
the dim dip aren’t necessarily to see but to be seen, modern grey cars just blend into the road at times
Posted : 27/11/2018 9:26 am
I just stick my (dipped) headlights on, I’m sure I couldn’t be bothered switching between headlamps and sidelights every few minutes depending on what type of street I was driving down.
I’m sure at least some people are flashing because they don’t think you’re sufficiently visible, not because they’re self-righteous idiots.
Posted : 27/11/2018 9:27 am
Fair enough, I guess the people doing the flashing maybe think they're doing me a favour e.g. highlighting I've not got my headlights on. Maybe it's just me who gets annoyed with needlessly bright lights on slow, well lit residential streets.
Very fair point.
Posted : 27/11/2018 9:28 am
manly Vauxhauls
Muscle cars?
Posted : 27/11/2018 9:29 am
not tedious at all but interesting in a ‘christmas conversation with father in law’ sort of way…
Haha, car chat is about all I can safely chat about with the F.i.L...
Posted : 27/11/2018 9:30 am
The new type of headlamps fitted to the likes of Range Rovers/Spsazqai etc are constantly appearing to flash.... hate them!
Posted : 27/11/2018 9:41 am
The worse one, however,  is sidelights with fogs when it’s clearly not foggy. Just plain stoopid!
The driver is probably also one of those chumps who is clutching a douche-flute whilst driving.
Posted : 27/11/2018 9:57 am
No, you're being unhelpful. Sidelights are for parking and are a pointless invention.
- You run the risk of forgetting to switch the lights back on if you drive into a darker area.
- What if the street lights go off?
- You also look muich dimmer than other cars at the same distance (in every sense of the word).
- Nearly all running and cycling gear has reflective strips on it which only works if a driver has their headlights on.
- If one lamp goes the only thing to make your car visible (and I bet it's grey or black) is a single 5W bulb.
- Cats eyes won't reflect.
- The police may think you've been drinking.
- People will pull out in front of you.
- In conditions will multiple light sources you'll actually blend in.
Provided your headlights are properly adjusted there is absolutely no benefit to driving on sidelights only. If you're being dazzled by other lights in a brightly lit area, you may want to consider an eye checkup as it can be a sign of developing cataracts.
Posted : 27/11/2018 10:12 am
This is fun. It's like a cycling helmet debate.
Personally, I applaud the OP, because the amount of selfishness around driving is staggering, and very few people think of the impact their driving  is having on others. And I'm not just talking about driving standards, but even things like your presence (which it seems this was an attempt to mitigate)
Unfortunately we've created a culture where we'd rather drive round with monstrously bright lights to be seen, than actually take the time to look properly in the first place. Whilst I've never done it myself, in my opinion, a world where we drive around our town centres at 20mph with only sidelights at night, sounds a much more pleasant place to live.
Posted : 27/11/2018 10:43 am
This ^ & Flaperon +1
Posted : 27/11/2018 10:54 am
I'm with flaperon. First thoughts on seeing sidelights coming down the road in the dark are that some old dear in an old volvo hasnt remembered to turn on their dipped lights and their driving is likely to be similarly away with the fairies so to be on my guard.
Posted : 27/11/2018 10:59 am
[My opinion] Perfect choice of words regarding driving at night with just sidelights[/My opinion]
Seems strange considering that bikes and motorbikes are encouraged to have brighter lights so they can be seen - each to their own though and if it's not illegal, then why not?
(but I'd flash you too)
Posted : 27/11/2018 11:05 am
Saves fuel to run sidelights only on my car.
Posted : 27/11/2018 11:15 am
I'm pretty sure most people would automatically assume somebody driving around at night with just sidelights on was either pissed or just an idiot, I know I would.
Is that even a real problem? I've never been bothered by a split second of extra light as an oncoming car went over a bump, do you really drive around with sidelights on for that reason?
Posted : 27/11/2018 11:16 am
Diesel headlights?
Whatever will they think of next?
Posted : 27/11/2018 11:19 am
Nope,  pop up headlights or illuminated air brakes.
Posted : 27/11/2018 11:22 am
I don't understand what negative impact it has, someone driving with just sidelights in a 20mph street lit area? Other than to people too impatient to look properly before they pull out in front of them (the same people who are likely to pull out in front of a cyclist who is usually illuminated about the same as a sidelight).
You may think it's a confused old dear or a drunk driver. But only because it's uncommon to see. Flaperon says a lot there, but do we even have cateyes on a 20mph residential street??  Most of it seems to come down to, "you're not doing what everyone else is doing - get in line". Hence why it's like a cycling debate - the answer comes down to, "Well, you should do it just because you should ... And I have an aunty Jennifer who once fell off her bike ... No, I don't care if the law says it's OK... You're an idiot, OK"
Meanwhile, the other week, I'm riding up the bike track at dusk, light pointing downwards to the floor and on the lowest setting. Guy walking past says 'Think your light's a bit high, mate'. We hear complaints about dazzling bike lights all the time. And I know they're not regulated in any way in this country, but I've never personally experienced it. Yet I do get dazzled by car headlights on a daily basis (especially with these new hid things, every time they go over a bump). It's not tolerated from bicycles, but it is from cars.
I do agree with the bit about forgetting to turn on your headlights - I once accidentally drove halfway up the M1 with just my sidelights on. I just think there are a lot of positives from the OPs behaviour - the thoughtfulness to do it in the first place being the main one.
Posted : 27/11/2018 11:27 am
I would assume you've forgotten to put your lights on properly ( or don't know how to) I'd leave plenty of room , but I wouldn't flash, as I don't think it achieves anything
Posted : 27/11/2018 11:30 am
Those are sooo last year - it's all LED now 😉
Posted : 27/11/2018 11:33 am
I’d leave plenty of room
Sounds like a few positives from doing it!
Posted : 27/11/2018 11:42 am
Those are sooo last year – it’s all LED now
I assume you mean laser? 😉
Posted : 27/11/2018 11:46 am
Laser lights!  Oooh, makes a note for next car...
Posted : 27/11/2018 12:08 pm
when you’re drifting round the corner with full oppo
Only if you're ham-fisted, it's always a 'dab' of oppo! 😉
Posted : 27/11/2018 12:59 pm
The only time I ever use sidelights is when I'm parking outside my house to avoid being dazzled by the headlight reflection off the car in front (and to avoid the light overspill going into my neighbour's front window).
The rest of the time, headlights. All the time.
If I see someone driving on sidelights only I assume they're a total moron. Which to be fair covers about 95% of drivers 95% of the time anyway* so it's a reasonably safe assumption.
*obviously I'm a perfect driver.  😉
Posted : 27/11/2018 1:08 pm
Only if you’re ham-fisted, it’s always a ‘dab’ of oppo!
Only if you're being half-arsed about it 😉  Go big or GTFH 😀
Posted : 27/11/2018 1:20 pm
Haha, have got to admit the fuel consumption thing did cross my mind, but only in a theoretical sense, I definitely notice the engine note changing when I run AC etc.
Is that even a real problem? I’ve never been bothered by a split second of extra light as an oncoming car went over a bump, do you really drive around with sidelights on for that reason?
Ever driven in Edinburgh? 😉 It's not like you're getting blinded, but it is annoying, in fact it's sometimes hard to distinguish if someone is flashing you or just bumping through the troughs in the cobbles with their dipped headlights.
Anyway, curiosity satisfied, at least some people agree I was trying to do the right think but seems like more good reasons to go dipped than not.
Posted : 27/11/2018 1:23 pm
When I venture into the city I employ a chap to walk in front of my car swinging a lantern.
Posted : 27/11/2018 1:34 pm
Nobody knows what sidelights are these days, or even how to operate the lights on their car. See muppets with auto lights driving along in fog/low cloud/heavy rain with no lights on at all.
I tend to drop on to sidelights if in the middle of a queue of stationary traffic in the dark, or someone is kindly reversing for me down a country lane. Not that I ever get that courtesy back. No, it's full glare 12" from my bonnet.
Posted : 27/11/2018 1:46 pm
At night in crowded streets with parking on both sides restricting the road to one lane , creeping about on sidelights is a real pain to drivers negotiating junctions - they cannot see you until you are on top of them and then there is conflict in the single lane - if you had dipped headlights on they would notice you from your lights reflecting off other cars and  street furniture.  This is similar to the point made above about your headlamps being part of the system that makes reflectors work on cycles and pedestrian clothing.
So it might be thoughtful in terms of light  annoyance , but its another kind of annoyance to others ,  also the brightness and design of sidelights/marker lights varies a lot - some are very distinctive and some not much good even as parking lights.
Posted : 27/11/2018 1:51 pm
I was going to suggest something similar.  It would need to be powered by a candle, though.  Proper old skool.
Posted : 27/11/2018 4:15 pm
 Nico
I want one of those manly Vauxhauls.
Posted : 27/11/2018 4:16 pm
I applaud the OPs thoughtfulness. I trust you also apply the handbrake whenever stopped to avoid dazzling those waiting behind you with brake lights? Some of the newer Audi & Merc ones are so bright they make me feel nautious.
Posted : 27/11/2018 4:57 pm
Ok, sounds likel it's time for a quick fag packet calc. Sidelights  are 5w. Dipped headlight 55w. So 100w extra for two.
The efficiency of an engine in converting fuel to electricity via the alternator is around 20% (so says Google). So that 100w extra output needs 500w extra input.
A litre of petrol has around 34.5MJ of energy in it. the lights need 500 J/s. So a litre of fuel would in theory power the extra lights for 69,000 seconds. Or 19 hours ish. Assume fuel is £1.30/l. That's around 7p an hour saved in fuel if you drive round with side lights instead of dipped. Don't spend it all at once!
*These numbers might not be right 😁
Posted : 27/11/2018 11:59 pm
Ah but you’re forgetting aerodynamics.
Posted : 28/11/2018 12:05 am
ADH that Lancia has working headlights? 😉
Posted : 28/11/2018 12:20 am
"Ok, sounds likel it’s time for a quick fag packet calc. Sidelights  are 5w. Dipped headlight 55w. So 100w extra for two."
"So a litre of fuel would in theory power the extra lights for 69,000 seconds."
What if the poster has a Zoe or a Tesla ?
Posted : 28/11/2018 7:46 am
Or if switching on too many luxuries, such as lights sees the Voltmeter dive through the floor. Causing a petrol car to run out of electricity.
Posted : 28/11/2018 10:23 am
Posted : 28/11/2018 10:32 am
Then it's new battery and/or alternator time
Posted : 28/11/2018 10:43 am
thatll be the OP but not the guy suggesting he uses more fuel .
he may also have a dynamo and thus limited electrickery
Posted : 28/11/2018 11:20 am
Unfortunately on the Merc the brakelights are linked to the automatically handbrake. Hence you can pull up to the traffic lights, putting your foot on the brake will automatically put the handbrake on in the 'Hold' position and leave the brake lights on.
I guess Audi uses a similar system.
Posted : 28/11/2018 11:22 am
 pdw
Even at 20mph, I wouldn't want to lose the benefit of being able to see reflective stuff.
Not generally, but I did encounter a pair of cat's eyes riding through my village last night.  I wouldn't have seen the moggy at all without throwing some lumens up the road.
Posted : 28/11/2018 11:29 am
I'd rather meet someone with side lights on than the numpties that are stuck on main beam.
Posted : 28/11/2018 2:07 pm
Amazingly, yes. They're about the only electrical system on the car which does work ... and it is 5 years since it last passed an MOT ... but all the lights work fine 🙂
Posted : 28/11/2018 2:57 pm
