Spain is sending up to 53 Leopards 👏
be in Crimea in no time
and be welcomed with flowers. Or maybe not.
This article is more than 7 years old.
The U.S and European Union may want to save Crimeans from themselves. But the Crimeans are happy right where they are.
That's one of the most extreme cases of selection bias imaginable. Any openly pro-Ukrainian Crimeans would have either fled or have been imprisoned or deported. Russians moved into Crimea after the invasion so the current occupants of Crimea are overwhelmingly pro-Russian. If Ukraine retakes Crimea and conducts a survey of Crimean residents, you'll find the exact opposite has happened - the pro-Russian people will have fled to Russia and the pro-Ukrainian Crimeans will have returned.
How long does it take to train crews up to be effective in these vehicles?
What level of adaption will they need?
That’s one of the most extreme cases of selection bias imaginable. Any openly pro-Ukrainian Crimeans would have either fled or have been imprisoned or deported. Russians moved into Crimea after the invasion so the current occupants of Crimea are overwhelmingly pro-Russian.
That may or may not be the case - I am guessing that you have no data to back up your claim. But I think it's useful to bear in mind that the story that's being fed us day after day may not be the whole truth.
According to a bloke on The Newsagents Podcast just now it's pretty straightforward and any teenager can learn to fire the gun in a few minutes.
Setting up the logistics chain might take a while - if that isnt done properly you end up with the Russian convoys north of Kyiv with no fuel!
I jumped into a Challenger and it took Less than an hour to be able to get it moving in the intended direction at a steady smooth speed. Admittedly this was a flat feild, with no one trying to insert an rpg into turret.
It will be the more techy stuff that takes time to learn. Crossing ditches or raised barracdes. Going fast backwards, getting out of mud when ypur bottomed out and the tracks are useless stuff.
Then there is the gunnery, targeting, smoke, machine guns, fuelling, re loading, in feild maintenance to learn.
Does that stuff differ significantly from tank to tank, or will Ukrainians experienced with their current kit already know pretty much what to do?
Not just that though. If you're in an area that's being occupied militarily, and someone asks you if you like being occupied, what are you going to say?
Yep.
https://twitter.com/bigSAC10/status/1618609882504257537
Im just going to recommend nobody go and look at any other of bigSAC10's Tweets!
There's stuff in there youll not be able to forget.
The basic principles of tank warfare will already be known. What they have to learn are the differant fire control systems and the differant gun loading systems.
Whilst a teenager can learn to press the firing switch in two minutes, target aquisition and basic gunnery principles particular to the tank in question will take a bit longer...plus the drills to follow should the gun not fire.
The Challenger has a fabulous ride, compared to older tanks, it will feel like an armchair compared to a T72.
It'll certainly help Ukraine having armoured squadrons, it's just another string to their defence, they'll have air defence to support their deployment as well, but it's only going to escalate further, talk from Ukraine is they'll now push the west to supply long range missiles and aircraft, which i can see being a real issue, on one side it's what they need to defend their country, but the flip side is that it could drag the west into a bigger war, we have had arguments, no matter how loose of the supply of defensive weaponry, but you start giving them long range missiles and combat aircraft and it's a whole other thing.
Is it? Russia are using them. It’s hardly giving then ICBMs. In fact when Ukraine gave up it’s nukes we promised to protect them…..
Theyve already received fighter aircraft, quite early on as well.
Do you mean aircraft that are not Soviet designs?
100-200 modern tanks of any flavour , plus 100 Bradleys, 50 Marder, 50 AMX10, 50 CV90, 100 new western SPG and hundreds of new APCs. Yes, that lot is pretty game changing.
Up against an estimated 15,000 Russian tanks. If it comes down to numbers, then Russia is not going to run out any time soon.
Russia does not have 15,000 operational tanks. They may have that many rusty old hulks sitting in storage depots, but they lost most of their modern tanks in the first few months. Now they seem to have stopped using tanks at all in their offenses - they're just sending in waves of conscripts without any armoured support. We aren't going to see massed tank battles, just tanks being used to support infantry.
Nobody knows for sure, but its likely going to be in the thousands anyway. And they can and will build more. So while the latest battle didnt use massed tanks, thats not to say subsequent battles will be fought the same way.
I think all we can hope for is to push Russia back across the border and leave it at that. But to do that means retaking the Donbas region, and thats only going to happen years hence, with considerable cost to both sides.
If Russia was able to build more modern tanks, they would have done so already. Same with pulling tanks out of reserve. They've already sent pretty much everything they can muster to the front. They do have thousands of old Cold War tanks in storage, but they will need extensive overhauls. The engines and transmissions will need to be stripped and rebuilt pretty much from scratch just to make them mobile. The armour will need to be upgraded with reactive armour, plus the electronic systems will need to be replaced with modern gear. Without modern armour and electronics, they will be sitting ducks for Ukrainian missiles and tanks. The electronics systems will use a lot of imported components that Russia cannot produce locally.
Milk and two sugars?
It’ll certainly help Ukraine having armoured squadrons, it’s just another string to their defence...snip
It's more important at this stage to turn this slogfest of attrition around, tanks will help in that. Longer range missiles, aircraft, etc would also be a big advantage and Russia has spaffed that advantage in its attacks on civilian targets
It won't have been missed in Moscow that western resolve has hardened when Germany decided to supply MBTs and they will be a lot more convinced that the west is in this for the long run
I'm not convinced that western aircraft are a short-term solution for Ukraine, but missiles would be. More tough decisions to come
It won’t have been missed in Moscow that western resolve has hardened when Germany decided to supply MBTs and they will be a lot more convinced that the west is in this for the long run
This is there whole gambit isnt it? To simply endure longer than the west by buying time on the battlefield with Russian lives. But theres only so long they can do that before the political situation in Moscow changes against Putins control.
Which is fine if you can inflict long term harm on the west, but thats looking increasingly less likely following the energy markets adjustments. (Funny how the freezing Europe narrative has largely died away and were back to Bio Nazi Satanists)
There will be price rises rises again Im sure, but nothing like we had last year now that much of the uncertainty has been removed from the pricing. And its not even just the west moving against Russia, both India and China are forcing heavy discounts on Putin (when not killing each other over a border dispute and investing heavily in infrastructure to improve military logistics to that border). And China isnt (unless Ive missed something) offering much more than words in terms of connecting to Russias main (the main fields that supply Europe arent connected) gas pipeline network either and has instead been busy signing LPG contracts with other suppliers.
Supposedly even some of the other raw materials Russia was heavily involved in have found new sources triggered by customers looking for reliable supplies, especially in the Americas.
Itll still drag on in to next year in my uneducated view.
I dont think the Challenger 2's will be roaming anywhere. The UK is very very keen that the Russians don't get a hold of a destroyed one.
I dont think the Challenger 2’s will be roaming anywhere.
Are you saying they will be sent to Ukraine with some kind of caveat that they aren't used?? What would be the point of that? I predict they will be used aggressively and effectively by Ukrainian tank crews once they get to grips with them and integrate them properly into a combined arms formation. The MoD will have carried out a risk assessment which will have acknowledged the risk of loss or capture. Whilst I'm sure they wouldn't be chuffed about it, they accept it might happen. I suspect some of the more sensitive equipment will be withheld because of this. The Challenger 2 was used operationally in Bosnia, Kosovo and the Iraq war and has also been sold to Oman so there has always been a risk of loss or compromise. Although upgraded several times it is a relatively old (though still very capable) tank soon due to be replaced by Challenger 3.
I would imagine there will be a procedure for destroying a disabled tank in the event it could be captured.
Hit it with himars or air to ground munitions. Trouble is with 35mm armour you risk reducing it to man portable lumps by blowing it up more.
Probably some men with pixelated faces from the uk will be around in the worst case of an intact tank being overun or more likely breakdown in a fwd area.
I read whatt to the layman suggested a reasonable reason for Challengers not going to the main front lines.
Theyd be park on the Belarus border along with the Abrams, and the Leopards would go ti the active rront line.
Shortens and secures the logistics for the small number of Challengers, the hard to maintain Abrams whilst securing that border freeing up Soviet built units to go east.
Leaving the Leapords as the only supply and maintenance chain that needs to be built ti the front line.
Just some dude on the internet admittedly but it sounded plausible.
Original purpose of these exact tanks was to take on the Russians on some Central or Eastern European plain. The risk of losing a tank to the Russians was always there.
The UK has said it wants the Challengers in theatre by March. The Abrams haven't even been built yet and won't be there for at least a year. The Ukrainians are already operating a very mixed fleet of armoured vehicles very effectively. Yes, it complicates the logistics but there is no way they are going to let capable gen 3 MBTs they have been begging for, languish unused at the rear somewhere.
Yes but in the full conflict scenario the chances are the Russians wouldnt have been able to make use of any captured equipment in time.
As it would take time to analysis the armour, for example, and then either build weapons which are specifically designed against it or to start including knockoff armour on your own tanks.
Sounds like the Poles are sending another batch of the more recently upgraded PT-91s as well as Leopards. Think the UAF have been using older versions for a while now.
I could be way off the mark but I have a feeling that when they're in Ukrainian hands Zelensky and his commanders will employ them how they see fit and to hell with the repercussions (if any).
And if anybody has put such conditions of use on their donation, they'd be a bloody fool to expect them to be honoured.
IMO of course.
Are you saying they will be sent to Ukraine with some kind of caveat that they aren’t used??
Not sure, article said something about them only being used to secure certain areas, where they can be easily recovered.
They even spoke about a forming a unit solely for recovery, especially in front line conditions.
But I dont know, understandable given how secret the new armour is.
I don't think Russia will gain much by capturing a tank intact. They haven't the luxury of time our expertise to develop new weapons to exploit weaknesses doing. It might just allow them to exploit them tactically at best.
The real beneficiary of any Intel gained will be Russia's best buddy, China.
Even then, Russia getting a bloody nose in Ukraine will further deter them from a potential invasion of Taiwan in the near term anyway.
Edit: CNN reporting that the relevant armoured retrieval units are being sent too, though not many. Sorry, can't remember their proper name. They can tow the tanks away for repair hopefully.
There are reports that Putin has told his generals he wants a large-scale offensive in the spring. It sounds like Ukraine wants to have NATO tanks in time to help repel that offensive, then to spearhead a counter-offensive.
https://twitter.com/TheStudyofWar/status/1619160066103427072
https://twitter.com/washingtonpost/status/1619554628714074112
Is it not also about recovering damaged tanks? Western doctrine is the safety of the crew and if a tank is disabled then the crew will sit tight and wait for recovery, like this http://news.bbc.co.uk/1/hi/scotland/2908679.stm Sgt Baird in understatement of 2003 said: "It was quite an experience."
Recovery of a MBT that can weigh up to 75T is no mean feat https://rheinmetall-defence.com/en/rheinmetall_defence/systems_and_products/vehicle_systems/armoured_tracked_vehicles/crarrv/index.php
You've only got 14 tanks and fewer recovery vehicles, which are also needed to perform maintenance and repairs on other MBTs so you want it to be as safe and easy as possible
There's a window of opportunity before the spring thaw and rain; an early offensive is unlikely to achieve much given its short timescale, but that must be a temptation knowing that delay will lead to trained Ukrainian MBT crews supported by armour and infantry. That decision will depend on whether the yet-again-newly-appointed RF military commanders tell the truth in the sack and blame culture
Former Chair of NATO's Military Committee and a former paratrooper, retired general Petr Pavel has been elected president of the Czech Republic and will take over in March.
70% voter turn-out and he doesn't have the same opinions on Russia as the current Czech president (who had a late epiphany during Russia's invasion of Ukraine).
An impressive career https://en.wikipedia.org/wiki/Petr_Pavel
Reports of explosions at several arms factories (making shaheed drones?) in Iran. Also footage of a drone being shot down in Iran. Responsibility is unclear.
Kurds / Israel being blamed by Iran. seems unlikely its ukraine
AnY Twitter links guys?
I can't see anything on the BBC/ CNN.
^^ Cheers!
There’s been plenty of rumours that Iran swapped drones/missiles for uranium/nuclear tech with Russia. Esfahan has long been a site for the Iranian nuclear programme. I know who my money is on!!
Careless smoking incident, innit.
Great article in the Wall Street Journal about a massive armaments repair facility in Poland which is working around the clock to repair and refurbish damaged Ukrainian armour and artillery before shipping it back to Ukraine. Factory technicians are also in direct contact with people on the ground giving them assistance in carrying out their own repairs in theatre.
Another of many examples of Poland punching way above its weight in supporting Ukraine.
Paywalled unfortunately.
Anyone catch the 1st Episode of Putin vs The West last night ?
Really well put together documentary. Really unnerving seeing what this madman is like and how he operates.
Yep. The fact we allow them to swan around buying up half of europe is mind blowing really.
Which has raised a query, how much of that has since been siezed/frozen?
I can confidently answer "not as much as we might have hoped"...
Anyone catch the 1st Episode of Putin vs The West last night?
Yeah, comes across as a cold psychopath. He's also surrounded by like-minded thugs.
yep, watched the first and second episode and half of the third.
Little man suffering from SPS and delusions of grandeur, hiding behind an arsenal of nuclear weapons.
Comes across as a complete 🔔🔚 who likes threatening people to get his own way.
Typical dicktator.
Putting the 'tater into dicktator since 1999
Watch out, Putin's about, watch out, Putin's about... You better watch out... Putin's about!
Another day another veiled thread of nuclear Armageddon.
"Those who hope to defeat Russia on the battlefield do not understand, it seems, that a modern war with Russia will be very different for them," the 70-year-old leader said. "We are not sending our tanks to their borders, but we have the means to respond. It won't be limited to the use of armoured hardware. Everyone must understand this."
Loving the spin on the tanks being sent too.
"It's unbelievable but true," he said. "We are again being threatened by German Leopard tanks."
https://www.bbc.co.uk/news/world-europe-64502504
However, certainly looks plausible that Russia might make some renewed offensive on the one year anniversary of the start of the invasion. Ukraine saying that Russia has gathered 500,000 men for the offensive...
……..with what equipment???? Their elite troops fell apart 50km into Ukraine last spring, so what are they expecting to happen this time?
Equipped with kitchen knives, building site helmets, wooly jumpers and vodka.
They didn't have any modern weapons for the last round of conscription so won't be able to equip a regiment properly.
We are again being threatened by leopard tanks. Anyone care to point out the glaringly obvious reply
Firstly. You started it midget man.
Secondly. You weren't being threatened by leopards before invading Ukraine, so its all on you buddy.
Standard Russian victim complex.
No, but you are sending your borders to our tanks
When was the last time Russia was threatened by Leopard tanks?
I take consolation that at some point in the future, Putin, Lavrov, Medvedev et al will die. I hope I make it to see that time. For now, as I think I have mentioned before, I wish them a happy hospice and palliative care.
Talk of a boycott of the Paris olympics is gaining momentum after the IOC said Russians and Belarusians can compete as independent athletes.
https://www.bbc.co.uk/sport/olympics/64503198
^^ Yeah, I saw that. Sod the Olympic committee. I love watching the Olympics but Russian/ Belarusian athletes just shouldn't be allowed to compete, full stop.
I think Germany did produce an armoured vehicle called the leopard during WW2 but no idea whether it was used on the Eastern front or whatever.
But yeah, the shit Russia is spouting isn't even worth fact checking it's so removed from reality.
BBC News - Ukraine war: US to provide long-range missiles in latest aid package
https://www.bbc.co.uk/news/world-europe-64518532
Does anyone know a bit more detail about what this means? I know that Ukraine has been asking for ATACMS for a long time, and this does not look like that, so what is it, what are the main differences and how useful is it likely to be?
These, apparently.
https://www.reuters.com/world/europe/us-rocket-powered-bomb-would-double-ukraines-strike-range-2023-02-01/
"(BRIGADIER) GEN(ERAL PAT) RYDER: So — thanks for the question, Joe. So — so yes, as part of the USAI package, we will be providing Ground Launched Small Diameter Bombs to Ukraine. This gives them a longer-range capability – long-range fires capability that will enable them, again, to conduct operations in defense of their country and to take back their sovereign territory in Russian-occupied areas." Full briefing here... https://www.defense.gov/News/Transcripts/Transcript/Article/3288141/pentagon-press-secretary-brig-gen-pat-ryder-holds-an-on-camera-press-briefing/
The longer-range capability stretches to Crimea so Russian logistics will be under threat in most of the occupied Luhansk/Donetsk region
The full package is in two parts; one from US military stock and one from Ukraine Security Assistance Initiative (USAI) funds... https://www.defense.gov/News/Releases/Release/Article/3287992/biden-administration-announces-additional-security-assistance-for-ukraine/
The GLSDB is USAI, which will come from industry and SAAB-Boeing originally said that they could deliver in Spring '23.
The two major GLSDB components are stock items in many NATO countries, the new bit is the interface to enable the rocket and bomb sections to work together. They can be fired from the M270 and M142 launchers that Ukraine already has, although I don't know if these will need some modification.
As far as I'm aware ATACMS is not on the table for Ukraine, but Abrams weren't a few weeks ago either 🙂
In WWII German tanks were Tigers and Panthers (plus others) but no leopards - they also had Puma armoured cars.
There were no Leopards in WW2.
I think the Russians would claim they were threatened by Leopard tanks during the Cold War.
https://en.wikipedia.org/wiki/List_of_German_combat_vehicles_of_World_War_II
None manufactured, but there were plans to make a light reconnaissance AFV bearing the Leopard name and designs were produced. The project got canned in 1943.
https://en.m.wikipedia.org/wiki/VK_16.02_Leopard
https://www.politico.eu/article/germany-send-leopard-tanks-ukraine-russia-war-rheinmetall/
REALLY, 88, from Germany, surely they could have found another to avoid that number!!!!
In case anyone is unfamiliar with the meaning, https://www.adl.org/resources/hate-symbol/88
^^ 😲 Oops!
Good news though, despite the inadvertent (I hope) dodgy symbolism! Older Leo 1s though, but will still be put to good use I'm sure.
This really is a proxy NATO war now. I am worried that Putin will go “**** it, I’m all in” on the 24th.
They're just numbers, both Germany and the UK supplied 14 MBTs, which has symbolic meaning for some.
Germany ordered 44 L2 A6 for Panzerbataillone 363 as one of two batallions in Panzergrenadierbrigade 37, presumably a total of 90 (with two Buffel recovery vehicles)
I'm sure that the numbers will be seized upon, after all, the first casualty in war is the truth (see Leopard/WW2 discussion^^) 🙂
My understanding is that 14 tanks make up a convenient unit, which is why we're seeing so many multiples of 14 or so (nothing wrong with a couple of spares lol)
https://youtube.com/shorts/olrCX2_XbLk?feature=share
I would argue it always was, which I don't view as a necessarily negative thing, it's just how geopolitics work
It would have been a Proxy War against NATO regardless of western support as it’s (to a degree you could argue about) meant to strengthen Russias hand against the west/NATO long term.
Yep, latest round of the Great Game I guess
