Two yr old went nut...
[Closed] Two yr old went nuts on the stainless steel fridge door
Our two year old went nuts on the stainless steel fridge door with a fridge magnet - lots of nice circular scratches on it now - who would have though to leave metal objects attached to the side of an object with a big smooth metal surface.
So middle class problems aside (it doesn't have a ghastly water dispenser in the middle of it) has anyone ever tackled scratches on a stainless steel fridge door, or do I hope I have toddler damage on my contents policy?
I've had a scan on the internet and there's various how-tos out there using bicarb, t-cut, toothpaste and the like but this place has the highest quotient of desirable-goods-to-toddlers on the planet so thought I'd give it a go to see if anyone's done it.
Posted : 28/03/2017 8:31 pm
If it doesn't work you could always wrap it.
Posted : 28/03/2017 8:34 pm
Wrap the child ?
Novel.
How about you feel less about material things whilst you have small children ?
Posted : 28/03/2017 8:36 pm
Blue scotchbrite. Worked fine on our Falcon stove top
Posted : 28/03/2017 8:38 pm
Frame it!
You have a two year old. I wouldn't rush to fix anything quite yet ๐Ÿ™‚
Fwiw ive found the toothpaste/bicarb tricks to be worthless. I would be taking a polishing disk and a drill to it but trying somewhere inconspicuous first. If its a matt finish then I have no idea ๐Ÿ™ - a fine scouring pad? 0000 wire wool?
Yeah not in a rush to fix it until he's old enough for a kicking (joooooooke) but thought I'd have a pop at it first to see if there's any likelihood of salvation. It happened on my watch though so keen to be 'proactive' despite a general 'balls to that I'm surprised it lasted this long' view.
Probably just end up painting it like a hippy's wheely bin.
Posted : 28/03/2017 9:00 pm
It will be covered in crapulous nursery art in no time at all. Enjoy.
Posted : 28/03/2017 9:01 pm
He's got an older brother and sister and their art is loads better so he doesn't have a chance.
Posted : 28/03/2017 9:03 pm
Posted : 28/03/2017 9:05 pm
He'll probably claim his scratchings are art, anyhow. You just 'don't get it'. ๐Ÿ™‚
This fridge, does it contain any pudding materials?
Posted : 28/03/2017 9:46 pm
You are Christo and I claim my five cans.
Posted : 28/03/2017 10:26 pm
Abduct a hipster designer give them an angle grinder and tell them to sort it.
Posted : 28/03/2017 11:18 pm
I have learnt this
Posted : 28/03/2017 11:37 pm
When my daughter was two, she got a magic marker and drew faces on lots of expensive stuff. I briefly considered throwing her a beating but then realized that all my friends are pinko-liberals who would probably take her side so I just decided to chalk it up as one of those amusing things that kids do.
Posted : 29/03/2017 12:03 am
Just a toddler being one.
Think of it as a story for the future.
Posted : 29/03/2017 12:11 am
 sbob
If it's steel then it can be polished out.
Can't tell you how difficult that will be without seeing it.
Posted : 29/03/2017 1:21 am
See yesterday's misreading title threads
Two Year Old Walnut on Stainless Steel fridge door -
Posted : 29/03/2017 2:13 am
Just wait till they can reach the hardwood worktops, smashing their breakfast bowls down & spilling milk. Went from a designer kitchen to a character kitchen quite quickly.
Posted : 29/03/2017 5:26 am
Our living room walls resemble an art installation. Squiggles in multiple colours everywhere ๐Ÿ˜ฏ
There is no way I'm decorating or doing anything about it until he's at least six. He's a proper crafty one though. Hides crayons all around the room. Think you've got them all, leave the room and then come back to a new piece of art from a smuggled crayon! Seems to have grown out of it now though.
Posted : 29/03/2017 5:38 am
Pics?
Stainless isn't magnetic
Posted : 29/03/2017 5:46 am
that's generally true but not universally true. Some stainless is magnetic, just not very. Apparently the other solution is just to use a thin veneer of stainless with regular steel behind
oh, and I took a quick look and apparently you shouldn't use wire wool so scratch that solution (excuse pun)
Posted : 29/03/2017 6:15 am
316 isn't magnetic . 304 is .
Back to the op,Mr Hutch has it ,cover the fridge in more "art".
Posted : 29/03/2017 6:32 am
It depends a lot on the surface finish of the material, whether it is actually stainless or just 'stainless effect' and whether there is any kind of top coating applied....
Where I used to work we made industrial equipment in 316 enclosures rated to IP66. The panels were stainless steel with a ground surface. Every now & again one would get scratched in build or test & could normally be recovered with a lot of elbow grease, a nylon scourer and some kitchen cleaner like Jif (or Cif as I think it's called these days...).
But equally, if the surface finish isn't right you could make a right pigs ear of it doing that!!
Posted : 29/03/2017 6:55 am
Olive oil. We had a similar issue in a rented flat (only it was my wife so I was allowed to become apoplectic and storm around the house) and buffing it with olive oil covered so the scratches
Posted : 29/03/2017 7:12 am
https://www.amazon.co.uk/STAINLESS-STEEL-ADHESIVE-APPLIANCE-COVER/dp/B008AJT7R0
Or go with something a bit more colourful while you have kids.
Posted : 29/03/2017 7:14 am
I'd not rush for perfection with a 2yr old....
You can start with auto restorer (In the UK we have a brand called T-cut)
You can also buy specialist appliance paint... but the results are likely to be poor unless you repaint the whole front.
I've used the appliance paint to cover some home-made parts around the extractor hood and it works quite well when you do the whole thing if you get a decent color match.
Posted : 29/03/2017 7:20 am
