i want to create a query that brings back those accounts whose first order has been in the last month.
Currently i have a select query that brings back the first order date for all accounts and then a second query that brings back only those accounts that have the first order in the last month.
Is there a better way of doing this? just that i have a two big tablea to query, so it takes a while.
Any advice appreciated.
query as is
select * from (select accountid, min(invoicedate)firstorder
from FilteredAccount
inner join filteredsalesorder fso on fso.accountid=FilteredAccount.accountid
group by accountid)d
where firstorder>DATEADD(m,-1,getdate())
I will ask our SQL guru at work, when he gets in ๐
You could look at using a [url= http://msdn.microsoft.com/en-us/library/ms176102.aspx ]rank[/url] on the order date instead of a group by. That may speed things up.
Something like (untested!):
[code]
SELECT *
,RANK() OVER
(PARTITION BY fso.accountid ORDER BY invoicedate) AS InvoiceRank
FROM FilteredAccount
INNER JOIN filteredsalesorder fso
ON fso.accountid = FilteredAccount.accountid
WHERE RANK() OVER
(PARTITION BY fso.accountid ORDER BY invoicedate) = 1
and invoicedate >DATEADD(m,-1,getdate())
[/code]
I see where acjim is going but id be looking to use windowing to do
MIN(invoicedate) OVER( Partition by AccountID)
And lose the bottom group by and the outer select (oops i think you still need the outer select for the where)
(select * is bad practice too but i presume you are just showing us!)
What DB technology?
for testing it is quick to write.
system is 2008 r2
Using the MIN() windowing function is more elegant, i wonder if it's more efficient? I guess the internal function is similar?
The other thing to do would be check your indexes - if you don't have one on invoicedate and accountid you should do.
i have been told by the DBA that the tables are indexed,
just got to figure out if the method your suggesting is quicker than how i was doing it.
never trust the DBA ๐
If you dont need the invoice date, surely the quickest way would be:
select distinct accountid
from filteredsalesorder
where invoicedate > DATEADD(m,-1,getdate())
I'm assuming accountid and invoicedate would be in a non-clustered index for a table like that.
If you need to only see particular accounts then maybe a CTE like so:
with monthoneorders
as
select *
from monthoneorders
join FilteredAccount on monthoneorders.accountid = filteredAccount.accountid
damitamit, what your giving accounts who have ordered in the last month, what i am after is the accounts whose FIRST order in the last month. Not the same thing.
Ah, sorry. Wasn't paying attention.
Another possible way to do it would be:
with orders
as
select accountid, invoicedate, ROW_NUMBER() over (partition by accountid order by invoicedate asc) as rownum
select *
from orders
join FilteredAccount on orders.accountid = filteredAccount.accountid
where orders.invoicedate > DATEADD(m,-1,getdate())
and orders.rownum = 1
Thou I'm not sure it will be faster than your original query...
