Toothpaste on car h...
[Closed] Toothpaste on car headlight - does it work?
My headlights on my Volvo have gone opaque, and look dreadful. I saw a tip that scrubbing it with toothpaste will renew the surface. Is this true, or an urban myth?
Posted : 23/11/2013 5:53 pm
Never tried it, but have used the meguirs kit, which has been enough to bring headlights back from no pattern just a blob to an mot acceptable pattern, worked much better than t-cut or g3.
http://www.meguiars.co.uk/product/397/Meguiars-Headlight-Restoration-Kit/
Posted : 23/11/2013 5:55 pm
It will work (eventually)
There are products designed to do the job, that are going to do it a lot better and a lot faster.
But essentially you are using a running compound to polish the tiny scratches out of the lens.
I use a specialist product for the job and it takes about 60 seconds per lens with a fast rotary polishing machine, or about 5 minutes by hand.
I've tried with toothpaste in the past and it takes forever, and can't achieve the same results.
[edit] - the Megs kit above is great for the price. It works well.
Posted : 23/11/2013 5:57 pm
This is what you want:
http://www.amazon.co.uk/3M-Headlight-Restoration-Discoloured-Headlights/dp/B0078IHJ1K
Posted : 23/11/2013 6:00 pm
Would Brasso work, isnt that abrasive ?
Posted : 23/11/2013 6:03 pm
Vim?
Posted : 23/11/2013 6:21 pm
Yes brasso does work, with a few minutes of elbow grease.
Posted : 23/11/2013 6:27 pm
What legend has posted worked a treat on mine.
Posted : 23/11/2013 6:34 pm
brasso also has a solvent in it, so may well melt the palstic shield of the headlight.
Posted : 23/11/2013 6:43 pm
Yes toothpaste works but usually need cheap runny stuff - takes a while - I found it better than Tcut
Posted : 23/11/2013 6:46 pm
