Community
Tiling directly on ...
[Closed] Tiling directly on to wood
I'm building up a kitchen windowsill that will be behind the sink.
I need to build up some box-work to mount the tiles on. My first thought was Aquapanel, but its expensive as i'll only use at most 1/3 of a board. I assume external plywood (or even plasterboard) will be fine, especially as the tiles in the bathroom are straight on to regular plasterboard (not done by me)
Posted : 19/11/2010 11:24 pm
ply is fine. go for the hard wood one with a textured finish, not birch, so its got a good key to bond to. If its just a small area 6 mm boards should do.
Posted : 19/11/2010 11:31 pm
I tiled directly onto plywood boxing in a bathroom and it's been fine for the past 15 years.
it will fine on any ply they do a tile adhesive specially made for wood which helps it move with the wood anyway so you wont have no problems there.
Posted : 19/11/2010 11:37 pm
Ply will cost you a lot more than a sheet hardie backer. Just use regular 12.5 plaster board and drywall adhesive to stick it. Double up the boards with a little dry wall addy in between.
If the area will be regularly exposed to water, you should probably give it a coat of water proofer/tanking solution. I use mapei gum but it's expensive stuff and you will only need a cupfull so probably best use hardie backer. Still fix it with dry wall addy though
As for adhesive, use either BAL, Weber or Mapei, however without a trade account you'll pay through the nose for it. I never use ready mix addy, only cement based but the tubbed stuff is fine for a kitchen.
Posted : 19/11/2010 11:43 pm
