Community
There's a whiff in ...
[Closed] There's a whiff in me kitchen, what am a gan do?
Our kitchen whiffs. No matter what we've tried to date, it whiffs. Case in point, we've just been away for a week and before we went all the bins were empty, the washing machine had been put through a self-clean cycle with some, er, washing machine cleaning stuff, ditto the dishwasher. When we got home after a week, the kitchen stank. As ever, it's a kind of drainy, binny kind of whiff.
I've put a plastic bag around the washing machine outlet, secured with an elastic band at each end, to stop any drain smells coming out of that. Dishwasher is plumbed straight in to to the sink waste, so can't get any drain whiffs from that. We regularly put boiling water down the sink. We're diligent about leaving the washing machine door open after use so it dries out. As above, washing machine and dishwasher get regularly cleaned with specific cleaner. We've pulled the fridge out and there's nothing festering under there. Anything else I can try/check?
Posted : 16/01/2020 10:00 am
Dead mouse somewhere? My folks found one under the cooker once!
Posted : 16/01/2020 10:03 am
I doubt it, but maybe. I think the dog would have let us know if there was something like that, cos he'd be going mad trying to get to it and eat it... Pulling the kickboards off to check there's nothing under there can't hurt I suppose.
Posted : 16/01/2020 10:05 am
Condensate drain from the fridge? They can get pretty minging. Not sure it would be bad or big enough to create much of a smell, but you've tried all the obvious stuff.
Posted : 16/01/2020 10:06 am
Where's that then? Worth checking, as on a previous trip away there was a power cut and the fridge/freezer was off for two weeks. The whiff we have is similar to that in smell, if not intensity...
Posted : 16/01/2020 10:09 am
What floor? If it's something impermeable like a vinyl you might have a leak at the back of a unit or even under the floor, a pinhole for example, and floorboards rotting under the vinyl. Don't ask me how I know this.
Posted : 16/01/2020 10:10 am
Floor is tile on concrete
Posted : 16/01/2020 10:12 am
Long shot but you're not getting air burping up past the kitchen sink u-bend when something else is drained are you?
Dogs are stupid - we had a dead mouse under the kitchen units that smelt and our two thought nothing of it.
Worth pouring some soda crystals down the sink (diluted as per instructions). Or strong bleach.
I had that in my first house.... stank.
And clean/bleach the bins.
Posted : 16/01/2020 10:30 am
Long shot but you’re not getting air burping up past the kitchen sink u-bend when something else is drained are you?
Don't think so, and that wouldn't explain the really strong whiff when we got back from being away; everything had been 'static' for a week.
I was going to do the soda crystals thing. Worth taking the U-bends off and cleaning them out?
Posted : 16/01/2020 10:33 am
I don't think it would be a dead mouse (or rat) - the smell from that would be gone within a month or so (depending on conditions).
Are you able to remove the kickboards of the kitchen units and have a look to see if there is anything suspicious there such as evidence of damp?
Posted : 16/01/2020 10:42 am
Yeah, that was the next idea.
Posted : 16/01/2020 10:45 am
yeah why not.... there's guaranteed to be a load of crap in there anyway.
Previous owner a Mr Fred West?
Posted : 16/01/2020 11:10 am
We had this last year & pretty sure it was coming from the sink/drain area.
When I replaced the kitchen sink, I ended up having to take all the drain pipework out & give it a clean (retch-tastic).
Since then, the smell has virtually disappeared. My Wife reckons she notices it, if we do a few washing machine cycles in a go, but I can't really smell it.
So I'd say it's worth taking the pipework out & giving it a clean through. I used some dowel & kitchen roll to wipe off as much as possible before cleaning the rest in hot soapy water.
Posted : 16/01/2020 11:14 am
Not sure you need to do that when this will do that plus more.
As a father to three, long haired, teenage girls, this stuff is a life saver when the shower starts clogging up with gallons of bloody conditioner and hair!
Posted : 16/01/2020 11:17 am
Check outside the external walls for evidence of blockages and pooling water or damp.
Posted : 16/01/2020 11:21 am
Good call. Weeping pipe could be rotting a kitchen unit.
We had some blood from a raw turkey run down the condensate pipe at the back of the fridge. Gathered in a small box above the warm compressor and started to really whiff!
Posted : 16/01/2020 11:44 am
Don’t think so, and that wouldn’t explain the really strong whiff when we got back from being away; everything had been ‘static’ for a week.
I'm going drain related too, if it's okay when you're home, drains are seeing a flow, not getting stagnant, then you go away and nothing moves, sounds like some kind of fluid barrier may have failed.
My Mrs insists on everything getting washed at 20 degrees, I'm not convinced it helps the drains either though, but agree with the eco angle.
Posted : 16/01/2020 11:47 am
Condensate drain from the fridge? - Where’s that then?
Design probably changes between manufacturers, but generally there's some kind of funnel arrangement in the internal moulding of the fridge compartment that channels any water into a small drain tube at the back. This drips onto a trough that sits on top of the compressor, heat from the compressor evaporates any collected water.
Posted : 16/01/2020 11:54 am
How does the kitchen sink drain? If it's a common drain with an upstairs sink or WC, water rushing down the soil pipe might be sucking the water out of the kitchen trap and allowing foul air to enter the kitchen from the sewer. There's no use in putting the plug in because foul air will still come out of the overflow. This would be happening because the air vent at the top of the soil pipe is blocked with a bird's nest or something and the water dropping down the soil pipe is creating a vacuum.
There might also be a mushroom vent at the top of the soil pipe inside a cupboard or under the bath.
Posted : 16/01/2020 11:57 am
sharkbait
Can you explain what you do with it, particularly the clearing long hair from a clogging bath drain?
I bought some soda crystals & it didn't really do much. I must have used it incorrectly...?
If the drain is clear enough to permit some flow, then any 'fluid' based cleaner that I put down the drain doesn't seem to do anything as it just drains away.
Posted : 16/01/2020 12:02 pm
Add 100gm crystals/1L of cold tap water (try not to breath the fumes) - pour down the drain and leave for at least half an hour, longer if possible.
Then pour a kettle of boiling water down the drain.... should be good.
Obvs you can do multiple 1L jugs if you want.
If the drain is clear enough to permit some flow, then any ‘fluid’ based cleaner that I put down the drain doesn’t seem to do anything as it just drains away.
I agree - it seems odd. But I think that as the fluid is seeping past the 'gunk' it attaches to it and breaks it down.
Posted : 16/01/2020 12:10 pm
Right, just whipped the base board off under the sink/dishwasher - underneath is full of crap, but dry as a bone. Ditto under the washing machine.
However, the drain from the dishwasher is a bit of a dogs dinner and isn't attached using one of the inverted 'U' hose guide things, as per the diagram on page 9 here:
Reckon tidying that up might help?
Oh, and the condensate drain from the fridge - there isn't one (well, not an obvious one). I have a feeling the air is cooled elsewhere and vented in as there's no 'cold plate' at the back, but there are vent holes at the top and bottom
Posted : 16/01/2020 12:39 pm
@sharkbait - thanks, I'll give it a whirl....
Posted : 16/01/2020 12:44 pm
Had a smell once in a rented flat. Turned out mice were nesting in the insulation around the oven of a freestanding cooker.
A few weeks after we had a leaky bottle of milk in the fridge the kitchen started to smell. The amorphous blob of cheesy fungus we found in the overflow tray of the fridge was not pleasant to get rid of...
Posted : 16/01/2020 12:51 pm
I'd start with the drains. I had a kitchen whiff which turned out to be a semi-open sink drain under the floorboards. Only started noticing it when the upstairs flat (old 70s house->flat conversion) put an ensuite in which used the same drain...it all made sense once I'd spent weeks diagnosing it.
Posted : 16/01/2020 2:02 pm
As well as cleaning the sink and putting boiling water and soda crystals etc down there make sure you clean the sink overflow too.
I periodically fill my sink with hot water and disinfectant and let it ‘overflow’ via the overflow for a minute.
Posted : 16/01/2020 2:12 pm
We get a stinky en-suite because the bathroom sink, which although in another part of the house is connected to the shower drain, burps back. A horrible sulphurous pong it is too!
A couple of bottles of drain cleaner down each sorts it for a few months then it starts all over again. I think it is hair (not mine, for I have none) and soap residue down the shower drain. Flushing it through with clean hot water for a few minutes keeps it fresh too.
Posted : 16/01/2020 2:14 pm
Dish cloth/sponge gone off?
Posted : 16/01/2020 2:19 pm
Sink overflow, as per modchop.
Posted : 16/01/2020 2:28 pm
I cleaned the ensuite sink trap out a few months ago. It was blocked near solid by strings of weird long green stuff that looked remarkably like seaweed. It smelled really bad. Sink was still draining (slowly). The bath - same ensuite - regularly gets blocked up too.
Preusmably, it's hair, for both of them, and fatty soap deposits.
Main bathroom user, my wife.
The other bathroom is fine.
Used almost exclusively by all the males in the household.
The overflow for the main sink is the little central sink. Both sinks get boiling water down them. There's no separate overflow
Nope, dishcloths washed regularly
I think I'll be getting some soda crystals at the weekend.
If it’s a common drain with an upstairs sink or WC, water rushing down the soil pipe might be sucking the water out of the kitchen trap and allowing foul air to enter the kitchen from the sewer. There’s no use in putting the plug in because foul air will still come out of the overflow. This would be happening because the air vent at the top of the soil pipe is blocked with a bird’s nest or something and the water dropping down the soil pipe is creating a vacuum.
It does share the same soil pipe as the two bathrooms upstairs. I'll flush both loos before I take the u-bends off, see if there's water left in there.
Posted : 16/01/2020 3:27 pm
Re: the soil pipe - how is it capped? Is it just an open end or does it have one of those valves that are designed to let air escape when needed? If it is, it might be stuck and foul air is being pushed back rather than released?
Posted : 16/01/2020 3:45 pm
our dishwasher was plumbed in after the U-bend and had an open vent. Drain stink cam through that and was much worst after a period of time away. Now plumbed in before the u-bend and all stink is gone.
Posted : 16/01/2020 3:53 pm
No the mushroom is an air ADMITTANCE valve. It's designed to relieve the vacuum caused high in the pipe when a rush of water goes down, otherwise the vacuum can suck water out of traps on the lower floors.
Posted : 16/01/2020 3:56 pm
No the mushroom is an air ADMITTANCE valve. It’s designed to relieve the vacuum caused high in the pipe when a rush of water goes down, otherwise the vacuum can suck water out of traps on the lower floors.
Ahh I stand corrected
Posted : 16/01/2020 3:58 pm
Have you been melting Putoline to wax your chain?
Posted : 16/01/2020 4:17 pm
I'll go with the fridge - pull it out and check the drain tray if it has one. They can get minging if anything has been spilt. Then the drains.
2 minute job to check the fridge.
Posted : 16/01/2020 4:34 pm
 tdog
Hopefully you haven’t got a mouldy parmegannio cheese chunk in back of fridge as this is potent smelling
Maybe worse than gone off prawns... :/
Posted : 16/01/2020 5:00 pm
My sink pongs a bit after a week away because the water trap gets gradually drained by varying pressures (not sure if it's air-flow around the house or just suction from the neighbour's drains.
Do you have a coffee machine that froths milk? Discovered the hard way you have to clean out various drip trays and air wands etc otherwise it really hums.
Leak inside bin leaving rotting water at the bottom?
Dead mouse is quite distinctive and obviously different (to me, anyway) from drains.
Posted : 16/01/2020 5:30 pm
I cleaned an undersink u bend recently, 2 years use, not v smelly but completely minging. Fats are a magnet for everything.
Posted : 17/01/2020 3:13 pm
Yep.
[posts picture of a rich, fat old bloke with much younger, beautiful woman]
Posted : 17/01/2020 3:46 pm
Washing machine filter thing? Mine smelt quite bad when it was partially blocked. Usually at the front/bottom, so may be concealed if there's a base board in front of it
Posted : 17/01/2020 3:49 pm
It will react with fats/grease to make soaps (which are soluble, and then in turn wash away more fats/grease). And it's corrosive so will eat the hair as well, but mostly it's getting rid of the gunk that binds all that hair together into a matted mess.
Posted : 17/01/2020 3:50 pm
Is your house new (or newish) build? We had a whiff in the kitchen on and off. Did the whole bin/ dishwasher/ washing machine clean thing. Took the kick boards off, the plasterboard behind the kitchen units was unpainted. Apparently (this maybe myth) the cheap plasterboard when it dries out fully over time can give off a chemical smell. Ours was chemical smell rather than a proper drain pong.
Obviously the rest of the plasterboard in the house had been over painted.
Posted : 17/01/2020 7:19 pm
Picture of dishwasher drain into sink waste needed. As mentioned, if it's plumbed in after the u-bend then it will have nothing to stop the smell.
Posted : 17/01/2020 8:52 pm
Right, so, an update. Things done to date:
- Washing machine cleaned with washing machine cleaner. Filter cleaned too.
- Ditto the dishwasher.
- Waste to dishwasher checked - it's on the right side of the u-bend as is now routed better so it's not looped around as much as it was.
- Sink waste, inc, overflow, stripped out and cleaned. Not a lovely job but really not that grim or stinky.
- Soda crystals/hot water in the sink waste pipes left overnight then flushed with hot water
- Fridge checked as best as I can; there's no condensation drain that I can see. Nothing on the inside, I even took the base panel off the back but that just had the condenser and the coolant 'tank' thing. No hint of a whiff back there either.
- Fridge pulled out, nothing behind/under it
- Kick boards off, no sign of damp.
There's still a whiff. What am a gan do?
Posted : 20/01/2020 2:47 pm
Move house?
Posted : 20/01/2020 3:01 pm
Ever see the film Se7en?
Posted : 20/01/2020 3:05 pm
Can't you narrow down the general location of the pong by sniffing?
FWIW my money's on either something lurking at the back of one of your kitchen cupboards or  a small leak from the washing machine running into the grout lines between the tiles. In 25 years of doing social housing refurbs, 90% of dampness / smells and rotten floors in kitchens have been ultimately traced back to the washing machine.
Posted : 20/01/2020 3:08 pm
Can’t you narrow down the general location of the pong by sniffing?
This is the frustrating thing; no. There's an overall whiff, but it's not stronger anywhere in particular.
I'll double check the washing machine and dishwasher for leaks. So frustrating.
Yep, I remember seeing Ms Paltrow in it and thinking she were purty. You've given me an idea for a scented candle to overpower the whiff...
Posted : 20/01/2020 3:26 pm
Fish?!
Posted : 20/01/2020 3:39 pm
What's above your kitchen?
Posted : 20/01/2020 4:18 pm
What’s above your kitchen?
Two bathrooms. Don't tell me this is going where I think it might be going...
Posted : 20/01/2020 4:33 pm
Don't rule out a dead mouse because you have a dog. We had mice getting in and stealing food from our cat's bowl for a number of weeks before sourcing the entry hole. The cat did nothing. Just asked for more food. Probably cut a deal with the mouse. Ba***rd.
Posted : 20/01/2020 4:38 pm
Have you asked the guys in the sewage works next door if they've noticed anything?
Posted : 20/01/2020 4:39 pm
Have you asked the guys in the sewage works next door if they’ve noticed anything?
They haven't. The fellas in the abattoir on the other side haven't either.
Posted : 20/01/2020 4:43 pm
Two bathrooms. Don’t tell me this is going where I think it might be going…
That depends if you think it's going in the direction of a leaky bath/shower tray etc trickling water down the inside of your kitchen wall. If it is, yeah it's going the way you think it's going.
If you were thinking Conti vert Pro, then no it's not going the way you think it's going.
If it helps I found the source of a manky foisty smell in my old flat when a damp patch became visible on the exterior brick about 5 feet off the floor.
That didn't help did it?
Posted : 20/01/2020 4:45 pm
(oh, and check any extractor hoses/routing, water pooling in those can stink)
Posted : 20/01/2020 6:13 pm
*Thread revival*
Well, you know what, I think I've sorted it.
Funny you should say that! I took the kickboards off and pulled the washing machine out over the weekend. The drain outlet on the wall is approximately twelve inches from the outlet on the machine. Between the two was about four feet of hose, with a gert big droopy loop 'twixt the two...
Hose shortened, whiff (so far) gone 🙂
Posted : 02/03/2020 1:30 pm
