The four corners of...
[Closed] The four corners of the World
Where do you think they might be? Geographically I would nominate the Western tip of Alaska, Tierra del Fuego, the tip of New Zealand and the Nordkapp I suppose.
Posted : 30/05/2013 10:14 pm
You do know the world isn't flat?
Posted : 30/05/2013 10:15 pm
Dobcross, Derker, Diggle & Delph?
Posted : 30/05/2013 10:16 pm
Bram Stoker's Carfax.
Thinking of quart-face, and inversion of the four corners.
Posted : 30/05/2013 10:17 pm
It must be flat. My atlas is flat, my screen with google earth on it is flat. The world must have a fair few folds though, just like my OS maps do..
Of course it's flat. If it was round, people would fall off the bottom.
Posted : 30/05/2013 10:22 pm
You do know what metaphors are don't you?
Posted : 30/05/2013 10:26 pm
Wasn't that the model before the Meta 5?
Posted : 30/05/2013 10:28 pm
when i was at school they said it was roundish as well have we moved on from that then?
Posted : 30/05/2013 11:14 pm
Well molgrips claims that he is only speaking metaphorically.
And yet despite that, he apparently wants to know where the four corners actually are ๐Ÿ˜•
Posted : 30/05/2013 11:18 pm
My eye is spherical and yet I can see out of the corner of it.
So a round earth can have loads of corners. 4 that spring to mind are
The corner of Wimpole and Wigmore Street (sturges v Bridgman)
the corner of Catoma and Meadville street
The corner of Giltspur Street and Cock Lane
The red corner (opposite the blue corner)
Posted : 31/05/2013 12:58 am
What do you mean out of "the" corner of your eye.....don't you mean out of "one" corner of your eye ? We're talking about 4 corners here.
Posted : 31/05/2013 1:03 am
this isn't the same as fork handles...is it?
Posted : 31/05/2013 6:46 am
Plenty of cultures represent the Earth with a square, due to the NSEWness of finding your way around.
Posted : 31/05/2013 6:51 am
Well tells us were the 4 corners are then !
Posted : 31/05/2013 9:28 am
The centre of the UK is Dunsop bridge, so why not start from there? Trevor in the cafe bakes great cakes.
Posted : 31/05/2013 9:30 am
You mean it might be variable ? It's almost as if the world is spherical.
Posted : 31/05/2013 9:34 am
A square needs two orthogonal axes, and extremes at either end of those. So the two combinations of two extremes gives four corners.
So you could have say.. heat as on axis and dryness as the other. Therefore the four corners would be the hottest driest place (Sahara probably), coldest driest place (a dry valley in Antarctica), the hottest wettest place (somewhere in the Malaysian jungle maybe) and the coldest wettest place (Manchester).
Posted : 31/05/2013 9:58 am
Looking at the map will tell you.
They are...
The North Pole, the North Pole, the South Pole and the South Pole.
Posted : 31/05/2013 10:00 am
