The Electric Car Th...
The Electric Car Thread
The indicated range in winter plummets if you do slow short trips i.e. town driving, because even a heat pump draws a lot of power to get the heating and cabin up to temperature, but you're not using much power for driving and not covering many miles.  So the power used as a portion of total consumption can be like 50%.  However on a long trip it should be only around 5% in the UK - and that's where range matters.  So when people quote drastic range drops in winter it's important to know on what sort of drive. I've had two heat pump equipped cars and the range drop on a long trip in winter was about 10-20%
Posted : 06/05/2025 2:55 pm
Government strategy appears to be pushing the burden to local authorities to come up with solutions, but there's no mention of price caps
The most likely local govt solution seems to be removing planning restrictions on cables crossing pavements or installing gutters, so you can run the cable from your house. This is a great solution but only if you can park outside your house.
Councils don't want to roll out infrastructure because they don't have enough money to run the services they have.
Posted : 06/05/2025 2:58 pm
Our work has just introduced the Octopus Energy Salary Sacrifice scheme. Given that all of the tax, insurance, servicing, breakdown cover etc. is included, it is quite a tempting scheme
I am doing this exact same thing. Comparing sums. We have a 2015 astra diesel with 123k on the clock. I think it'll need a clutch and DMF soon. its the unknown of what else can go wrong and when to consider another car. Also taking into accout depreciation. Octupus offering 6p/kwh at night + insurance, servicing etc + charger install. we do 12k a year
Trouble is i'd want a tow bar fitted to use my bike rack and if we can tweak things in terms of insurance - my wife is a garden designer. I'm going ot enquire if we could get business insurance for her
Posted : 06/05/2025 3:27 pm
I'd agree that leaving it all to the market is probably not going to produce a fair and equitable solution for all. That's what governments are for after all. But I do think the current high prices are driven by companies looking to fund expansion in order to get into a dominant position and once coverage reaches saturation point they will have to start competing on price.
I guess it could end up like diesel prices at motorway services.  You pay a huge premium for convenience, except that because the cheaper option is to charge at home that premium ends up being payable at any garage.
Part of me really thinks we should just get on with the process of ripping off the band-aid that it on-street parking.
If the house doesn't have parking, then it was probably built within walking distance of local employers. If it's not walking distance of your employer then you're just displacing someone else who could walk to work 🤷
Someone will inevitably argue that this disadvantages poor people who can't afford a house with off-street parking.  No it doesn't. On street parking disadvantages poor people who can't afford a car by removing a significant amount of the price premium that should be attached to having parking so they're forced into paying for an asset they don't even use or own.
Posted : 06/05/2025 4:06 pm
I have a salary sacrifice lease car through work and i specced it with a towbar, it's usually in the standard options assuming it's something the manufacturer offers.
Posted : 06/05/2025 4:17 pm
Ok, I think large scale relocation of people, restructuring of cities and transport modes is probably a lot harder than installing on-street chargers.  Also off-topic 🙂
Posted : 06/05/2025 4:19 pm
 rone
Useful info. Trouble is for us that's what we use an EV - lots of small trips.
Posted : 06/05/2025 5:03 pm
But therein lies the key benefit of not installing those chargers (or allowing trailing cables).  It allows those streets to empty out of cars and be gentrified / pedestrianized / LTN'd gradually over time.
https://pbs.twimg.com/media/Eza9e7iWUAAAI2Z?format=jpg&name=small
It's already happening in a more top-down way in Reading, there are lots of new developments with little or no parking at all including no on-road parking nearby.
Posted : 06/05/2025 5:11 pm
Posted by: rone
So (assuming home charging) unless you're doing something like 15 10 mile trips a day range doesn't really matter.
Posted : 06/05/2025 5:18 pm
It's not trouble though (with home charging) - you are unlikely to be doing 150 miles of short slow trips in a day.  The only problem is that the estimated range on the dashboard might say 150 based on your previous usage, but it will work out much more when you take that long trip.  And you would need to know what to expect if you were to do that.
Posted : 07/05/2025 9:10 am
 rone
But most of my trips across a week for the last 7 years (even charging at home) in the winter are not showing good efficiency.
I'm a bit unsure what you're saying about the range. Isn't the range based on current driving?
Posted : 07/05/2025 12:40 pm
It's based on the recent history of the car - I'm not exactly sure how it's calculated or over what time or mileage, but my Hyundai seems pretty consistent whereas my Nissan wasn't.
I'm saying that the range indicated on the dashboard isn't necessarily relevant to a long trip you might be doing - just as it would be in an ICE car.  So if you do these slow short trips in cold weather your efficiency for those trips might be 3 miles per kWh. Then, with a 50kWh battery, it'll say your range is 150 miles.  But if you go on a long trip you might actually be getting 4.5 m/kWh, which would give you a range of 225 miles. But when you set off, your dash will still be saying your range is 150 miles.
Your car is actually more efficient in driving terms at low speed, but your heating and electronics are using the same as if you were driving fast. So there are fewer miles against which to offset their energy usage. So you are using less energy per hour, but not less energy per mile.   Your heating uses maybe 3kW for the first 5 mins on a cold day, but if you live on a busy road you might only have driven 100 yards in that time and used 500Wh of battery.  Those numbers would give you an efficiency of 0.2 m/kWh during that 5 minute period.
Posted : 07/05/2025 1:02 pm
 rone
Useful. Comprehensive, thanks.
Need to assimilate that - always thought range was battery capacity/ current power draw.
I have noticed on the Citroen the range drops massively for about 80 miles then slows down.
Posted : 07/05/2025 1:32 pm
Huh, weird.  Manufacturers do seem to vary hugely, I have no idea what they do. I've heard that Tesla always starts (or used to) with the WTLP range and then changed according to that particular drive, which seems inadvisable - but maybe not due to the above scenario.  My car seems to take a pretty long view since it never changes except with the seasons. I also suspect it takes the ambient temps into account since you can finish a trip in the afternoon with a certain charge level, then if you don't charge it might be down a few miles by the following morning if it got cold overnight.
Posted : 07/05/2025 2:05 pm
 rone
Okay many thanks for this.
It's given me food for thought.
Posted : 07/05/2025 8:25 pm
The Zoé adapts quite quickly, do a few motorway miles and it's soon adapted and giving a realisitic range.
As for cold starts, I've got into the habit of putting the car in the well- insulated garage, and putting a ski jacket on. I just use the heater if the screen starts misting on long runs. The heater is crap when it's really cold anyhow.
Posted : 07/05/2025 9:13 pm
If you have heated seats and steering wheel, that’s much more efficient to use than space heating. Slightly different feel as far as comfort goes.
Posted : 07/05/2025 9:18 pm
 rone
Is this the difference between having a heat pump and not?
I'm convinced our first gen Kia Soul didn't have one - took forever to warm up. E-C4  has one, rapid heating system.
I've really not followed the tech of Evs despite leasing them for years.
Got to say I'm still pleased with EDFs electric cheap off-peak rates because of the amount of hours they provide. Even if it's not the cheapest. (22:00 - 08:00 week day and all weekend.) 14p. Means i can do all the washing and enjoy the weekend etc guilt free.
Posted : 08/05/2025 5:38 am
Possibly a niche question for this thread & might have been covered in the preceding 00’s of pages, but looking at a tusker salary sacrifice Skoda enyak (or sealion 7 if I can get past the daft name) and wondered if anyone here had opted to purchase the ev after the 3 year lease and  could offer some insight into what tusker refer to as “fair market price”.
ive spoken to them and its a value derived from autotrader and something else (caps maybe ?)
im not even sure its worth thinking about, but i am curious, as ill probably be stopping work in a few years after this term, so would rather not be without a car then.
still struggling with the man maths on leasing and not buying secondhand outright. But that’s really off topic.
Posted : 08/05/2025 6:58 am
The problem with any heat pump is the COP when it's really cold. Getting in the car at -20 in a ski resort a heat pump is barely more efficient than a resistance. Thecaptain has a good point, in those conditions a heated screen/seats/steering wheel are better than a heater. The Zoé shares its heat pump for cabin and battery. When it's really hot the A/C is useless and when it's really cold th eheater is useless.
Posted : 08/05/2025 7:06 am
@walowiz not sure if this helps but...
CAP is a well known industry set of value tables (like the old Parkers books that used to come out monthly and Glass's, which was more trade oriented).  CAP has various condition values that range from basically the auction house to pristine retail.  I'd guess it'll be a number between auction and dealer screen price they want.
I'd expect they'll value against CAP/Autotrader at the point where you express interest/they are able to offer it to you.  You won't get a value now as the market may still have some volatility as things settle down further amd changes in volumes over the intervening 3-4 years.
Posted : 08/05/2025 7:20 am
@walowiz
PCP might give you more certainty on the final value but more expensive overall.
Kia explains well
https://www.kia.com/uk/about/news/pcp-vs-lease/
Posted : 08/05/2025 7:36 am
Posted by: rone
Can only speak for the Musk ****panzer but the heat pump has never struggled in my 4 years of ownership with one. Toasty air from the vents within seconds of getting in the car. There is a degree of resistive heating from the various computers and motors that share the coolant loop, though, and you can sometimes feel the motors shivering to generate additional heat.
Posted : 08/05/2025 7:50 am
I was always conservative with the heat, but one morning when it was -4 and I had the Leaf I decided to treat it as a normal person would and whack it on 22.  It warmed up in about 15 seconds.  Not sure if it was the resistive heater or heat pump doing that, but it worked nicely.  That's the same trip I realised the slow short trip thing because the efficiency went through the floor.
Regardling leasing:  Someone buys a car, and plans to sell it after 3 years.  They then let you drive it, and pay them for the privilege. Your payments cover the depreciation, risk, and their admin costs.  The differences between you borrowing the money to do it yourself is that you don't have to pay their admin cost; and they might get a better deal on the new car to begin with because they are buying in volume. They might also self-finance or get better interest rates.  But the mechanics are the same.
The only benefit to you is that you aren't exposed to huge depreciation shocks and you don't have to stump up for a large loan or put loads of capital in. Getting an unsecured loan of more than £25k isn't particularly easy or comfortable (you're on the hook for the money regardless) and that doesn't go far when it comes to cars.
But the massive benefit to buying is that you can buy used. New car deprecation is huge, and if you buy used someone else has paid that. If you buy at 3 or more years old the depreciation is likely to have slowed to the point where it broadly keeps up with your loan payments so you if you need to you can sell the car and cancel most of the loan (or make some money back towards the end of the term).
So I think leasing is not a bad idea if you want a new car every 3/5 years, but regardless of how you finance it this is a very expensive habit.
Posted : 08/05/2025 9:43 am
Posted by: garage-dweller
yep, not expecting a value now, just wondered if anyone has done this and has an example of whether it was a good deal or not at the end of the 3 years lease on salary sacrifice.
I'm not expecting a good deal tbh as it’s their car and their business is leasing.
Posted : 08/05/2025 11:09 am
Arval's offer to me at the end of the lease was not too bad.  But how good or bad it is depends on the market situation in 3 years' time.
Posted : 08/05/2025 11:24 am
 mert
They are fairly complicated models in the cars i've worked on. Averaging over the last 1000-2000 km of driving with different weightings depending on how long ago it was, and how much of that type of driving you were doing etc etc.
Using instantaneous, or even near instantaneous consumption would see your range fluctuating from infinity when you coast or regenerate to sub 50km when you start up and leave the house. (My last full ICE had a consumption of about 6-8mpg getting from the front door to the main road.)
More like 5-7kW in anything bigger than a small hatch.
FWIW when i hit motorway speeds, rolling at 100kph uses between 25-30kW. Maybe 80 to accelerate to that speed. The slow steady roll to the kids school (mostly 50 or 70 limits) is using about 13-15kW to maintain speed. Heater is still using the same 5-7kW.
(I've had several fully instrumented EVs to play around with. Sorry, to do detailed analysis and test of...)
Posted : 08/05/2025 12:38 pm
VW (via BCA) offered me my lease cars to buy at the end of the term. The prices were what you'd expect for that car on a VW dealer's forecourt - so maybe worth buying if you wanted that exact car but no bargains to be had.
Posted : 08/05/2025 12:44 pm
Maybe in Sweden.  Do you have uprated gear? I've never seen the consumption go over 3kW in either of the two cars I've had but they are downmarket cars and I've only got the energy breakdown on the dash to look at.
That seems huge, to me.  Even with a 90kWh usable battery that's only 3hrs of driving which would be 300km.  When I look, mine's about 12kW at motorway speeds which ties in with my range numbers.  Are you in an E-XC90 or something?
Posted : 08/05/2025 2:46 pm
 mert
Nope, standard ish fitment for most C-D-E class cars across maybe a dozen manufacturers that i'm aware of. Not many companies fit different sized/powered systems for different markets these days. Sometimes they may have deleted the auxiliary PTC elements in warm markets. I know Ford and GM used to do that BITD. I'm not even sure if anyone still fits them now that 400V systems are available.
Nope, that's from test data. I'd have to double check to find out which car.
And FWIW most of the test cycles used to work out your rated range average out at about 45-50kph. So massively less than rated range at about twice the speed used in the test cycle wouldn't be hugely surprising.
Posted : 09/05/2025 9:10 am
 DrP
Yours is a lightweight, single motor vehicle though.. And it seems impressively efficient!
My polestar 2 cruises at the above suggestion (25-30kWh, at about 60mph)...
I think the single motor, newer version has more efficient motors and probably averages 18-20kWh at 60..
DrP
Posted : 09/05/2025 9:29 am
Does anyone know anything about the budget end of the EV world?
My daughter recently passed her test. She doesn't want to go very far (just drive to work 7 miles away and visit friends locally) and I'm going to get a charger installed in case I ever actually make a decision about my own EV. So it seems that an old EV might suit her well. Free charging at home and theoretically more reliable than an old ICE car.
I had a quick look at the budget end of the market on autotrader (~£3.5k) and it seems to just be a choice between Leafs (poor battery management) and higher mileage (or battery lease) Zoes (motors made of cheese). Anything I'm missing?
Posted : 09/05/2025 10:31 am
£7995 gets you a 20 plate Hyundai ionic near me. (Independent garage north Manchester.) Not sure of the mileage but it looks like the premium se version. Low insurance category.
Above the budget but might last several more years?
Posted : 09/05/2025 10:42 am
for young drivers the insurance can be exorbitant.  Our boys are 18 and 22, and have a Polo and a Corsa ICE respectively.  We looked recently at trading in the 71 plate Corsa for a new electric one, and the deals were quite good, but for a 22yr old in South Lanarkshire, with 3 points and 4 yrs of driving, his insurance went from £1000 to over £2500...
Posted : 09/05/2025 10:44 am
Thanks. Insurance is definitely something we'll have to look into more closely and does seem to be a negative of EVs.
To complicate matters she is looking at jobs all over the place (maybe not even in the UK) so it might only be needed for a few months (although could keep depending on where she goes). So, something cheap that she wont lose much on if she has to sell it on is probably best.
Actually the best option would be some sort of short-term or pay-as-you-go insurance on one of our existing cars, but those sort of policies (for brand new drivers) don't seem to exist anymore.
Posted : 09/05/2025 12:33 pm
£5k might start to get you into a BMW i3.
Posted : 09/05/2025 1:00 pm
Leafs and Zoes do work well enough.  Very early Leafs had poor battery management software, but from I think 2014 on they have used software to limit the damage.  This lead to 'Leafgate' where when the battery gets to hot you go into limp mode, but this requires lots of driving and I think three rapid charges in a row.  The battery doesn't get hot driving unless you're in Arizona or something, but it gets hot when rapid charging and it doesn't cool down very quickly at all, even in the UK. So the cumulative effects of two or three rapid charges push it over the edge.  Also the software on the 30kWh is worse than the 24kWh, and the 40/62kWh models.
As above though, the Ioniq 28/38kWh are much much better cars, and are likely to last decades. They're also perfectly usable and comfortable for long trips should the need arise.
Posted : 09/05/2025 1:08 pm
@roverpig, I think the early leafs use a chademo charging plug so keep that in mind if you do get one and install a home charger. All EVs nowadays use the CCS charging plug which has helped standardise things.
Posted : 09/05/2025 8:34 pm
It's Chademo for rapid charging, but they all use the same plug for slow charging on AC.
Posted : 09/05/2025 8:36 pm
Posted by: molgrips
I never knew that, good to know. Every day is a school day.
Posted : 09/05/2025 8:53 pm
Posted by: andy4d
…for rapid DC charging.
https://en.m.wikipedia.org/wiki/Combined_Charging_System
Posted : 10/05/2025 7:33 am
^ that is one big plug
took two more EV’s out for demo drives, Škoda enyak and BYD’s sea lion 7. I think they’re similar size.
the Enyak is a good car, not as quiet on the road as the id4, bit hard plasticy inside, but not a bad place to be in, acceleration is good, really good to be fair. And the screen console thing that gets so lamented was actually easy to use, boots cavernous which would great to transport bikes. The ride is harsh though, some unwelcome noise from the front, that we didn’t hear when driving the id4, both use the same platform, so I believe.
but the sea lion 7. Tested the dual motor option and in a word it is fast, really bloody fast when you ask it to go. Smooth round town, easy to drive, quite different to the Škoda, but really good. Interior finish level is also fantastic. Made the VAG offerings we’ve tested look budget. Boots not as big as the enyak, but it does have a frunk. And the amount of standard kit it comes with means there are no extra options to pay for or play around with on an online configurator. We were super surprised at how good the byd car was. the rotating screen is a bit gimmicky & the sunroof doesn’t open, if I’m being picky. Warranty is good on these, like Kia I suppose.
Actually liked the shape and styling of the sealion.
what I don’t know is how good byd are as a long term car, or for reliability. Anyone got one ?
Posted : 10/05/2025 4:57 pm
I’ve yet to look at the Sea lion 7. Earlier in the year I looked at the BYD offerings after seeing a Seal down a nearby road. The Seal looked pretty good (albeit it is a saloon and therefore not on my list). The BYDs I poked around seemed good. BYD and Geely and Xpeng etc are established manufacturers, just not well known here…yet.
Like BYD, one of the real appeals of Teslas was there was none of the this option, that option, this package stuff and haggling that is still weirdly common among ‘German’ manufacturers and dealers that takes you from an OK starting price to ‘what!?!’  That BYD, and Polestar to some extent, are providing lots of kit as ‘standard’ seems good to me.
I think it was Volkswagen where I saw that things like a heat pump were a £1,000 ‘extra’. 🤷🏻‍♂️ in an EV in 2025 I’d expect that to be standard.
Posted : 10/05/2025 9:27 pm
I think early Leafs had a type1 AC connection, later Leafs had/have a type2 AC connection. I might be mistaken but would recommend you check if buying. I also think the early Kia Soul was type1 AC
Posted : 11/05/2025 2:56 pm
Putting a heat pump on everything makes as little sense as putting AWD on everything.  It only really makes difference on long range once the car is up to temperature.  For short journeys it makes about 1-3% difference to the  m/kWh.
Posted : 11/05/2025 9:35 pm
Page 193 / 235
