That thing where yo...
[Closed] That thing where you use fire to seat tyres
Has anyone actually done this to a car tyre and do you need a compressor to pump it up after or will a track pump do?
Posted : 19/10/2014 4:09 pm
Pictures Or It Doesn't Happen
Posted : 19/10/2014 4:12 pm
it originally came from the icelandic offroad 4x4 community.
Posted : 19/10/2014 4:33 pm
Done it with motorcycle tyres to seat the bead then used a track pump for the correct pressure.
Posted : 19/10/2014 7:07 pm
Well I had a go with IPA but got nowhere, I'll try butane next quiet day. What did you use flicker?
I'll try to get pics if I can prop my phone up ๐Ÿ™‚
Posted : 19/10/2014 8:53 pm
I'd do a bit of research and use the right accelerant first time. Although people do it it largely held as a last resort - if you're half way up a glacier with the tyre off the rim and its going dark then its a trick worth knowing - if your not its a pretty dangerous thing to do even if you're using the right stuff to do it.
Posted : 19/10/2014 9:11 pm
When I'm halfway up a glacier with a tyre off the rim, and its going dark, I'll be glad I practised in the garden ๐Ÿ™‚
People seem to use all sorts, ez start popular but who has a can of that lying around these days.
I take your point tho, ill start small.
Posted : 19/10/2014 9:27 pm
@sweepy
An old can of brut deodorant, hairspray, pretty much anything really.
Once you've got the tyre on the rim push the tyre down and spray inside for a couple of seconds (don't be shy with it) and then use the can like a flame thrower. Job done ๐Ÿ˜€
Oh yes, make sure you've already fired the new valve and the core is in it too.
Don't worry it'll be fine, eyebrows/fringes grow back......
Posted : 20/10/2014 8:20 pm
Brut, hairspray, another two things I've not seen since the seventies ๐Ÿ˜€
I've got gt85 or lighter gas. I'll ask the girls at work.
Fringe will grow back you say, not without a time machine it won't.
Posted : 20/10/2014 11:11 pm
sweepy - Member
Then you're the ideal person for the task, a plan with no draw backs.
What could possibly go wrong ๐Ÿ˜€
Posted : 21/10/2014 9:30 am
Mmmmm, BBQ'd Stans ๐Ÿ˜€
Posted : 21/10/2014 11:52 am
strugling to see a point in this ....
"things im unlikely to have in my backpocket on a ride"
1. deoderant/ezi start/ipa etc.
2. lighter/matches etc
Posted : 21/10/2014 12:27 pm
So what's the science behind this? The resulting vacuum in the tyre pops the bead on the rim?
Posted : 21/10/2014 12:31 pm
explosions innit.
Posted : 21/10/2014 12:33 pm
torsoinalake - Member
Vacuun?
Rapidly expanding gases from the resultant explosion - think pop bottle on steroids.....
Posted : 21/10/2014 12:36 pm
The explosion, of course.
http://www.ebaumsworld.com/video/watch/82622204/
Posted : 21/10/2014 12:38 pm
scrumfled - Member
Right at the end of the programme 23:54
Posted : 21/10/2014 2:45 pm
