Syncing music on an...
[Closed] Syncing music on an iPod without a cable....
I've got an older iPod touch (with the older iPhone4 connector) which I use for work and I need to put some more content on it but I think the connection point inside the device has broken. It will charge but the computer doesn't recognise it when connected. So is there a way to sync it without a cable? Had a quick Google and the only way I could find needed a cable conncetion first. Anyone have a cunning plan?
Posted : 23/01/2017 8:53 am
Apologies for the obvious question, but have you tried another cable?
Posted : 23/01/2017 8:54 am
Sorry forgot to mention I have tried several cables all to no avail.
Posted : 23/01/2017 8:58 am
Probably another obvious Q but had you ever selected the device to enable iTunes wifi sync when the connector was working?
Maybe worth checking in Settings - General - iTunes WifFi Sync
[url] http://www.imore.com/daily-tip-set-itunes-wifi-sync-windows [/url]
Posted : 23/01/2017 9:11 am
Well... stuff purchased in iTunes will show on the cloud, so when you go into the Music app, it will be available... but stuff not purchased from Apple? Probably can't be done.
Posted : 23/01/2017 10:53 am
Have you cleared the connector hole at the bottom of the iPod?
If not, use a paper clip and gentle clear any fluff out. It's amazing how much gets in there and it can stop the cable connecting properly.
Posted : 23/01/2017 10:58 am
Just blow in it first, before sticking metal objects in there. (And if you do stick metal objects in there, switch it off first!)
Posted : 23/01/2017 11:03 am
the-muffin-man - Member
Or just use a non conductive wooden cocktail stick?
Posted : 23/01/2017 11:21 am
I've got a spare old Touch you can have - bound to be a vid on Youtube that'll show how to swap the connectors over... (Price of postage)
[edit]I don't think I binned it.. will have to check later
Posted : 23/01/2017 11:42 am
Thanks for the offer DezB but I am not the most gifted at practical things. Knowing me I'd completely trash the thing. 😳
Posted : 24/01/2017 1:01 pm
http://www.thecomputerroomnottingham.co.uk/iPod-Touch/iPod-Touch-4th-Gen%20/iPod-Touch-4th-Gen-Services - £40. You could probably get a replacement from eBay for not much more, but if you need to keep the one you've got...
Posted : 24/01/2017 3:50 pm
That's a lesson for life, kids.
Posted : 24/01/2017 4:02 pm
