Switching to Window...
[Closed] Switching to Windows 8
Guys,
Just received a new laptop at work, I've seen others using Metro for months and thought it looked clumsy, now I've got it, but its even worse as I don't have a touchscreen like they do!
So, what is the best way to use (or avoid) the Metro tiles?
I'm on a locked down laptop with no access to Metro Apps, no touchscreen, and it also appears to have a rather clumsy buttonless touch pad that you can tap, but for some reason also positively clicks down when you add pressure, but doesn't appear to reliably act as a click.
Can I avoid metro altogether? I don't understand why I have some sort of hybrid desktop plus Metro!
Posted : 02/05/2014 6:13 pm
Why is it so hard to just click on them with a mouse instead of a finger?
The touchpad is probably configurabe.
Posted : 02/05/2014 6:15 pm
I used to have several quicklaunch icons for my common programs but seem to be limited to full size icons now so I can't get many pinned to the start bar
Posted : 02/05/2014 6:16 pm
well for a start, the mouse doesn't seem to open the various swipe menus very well (you need to understand I've seen it being used on touchscreen laptops fairly regularly)
I know its new and I'll get the hang of it...but its a big change. Looking for tips basically.
Posted : 02/05/2014 6:17 pm
You don't swipe with the mouse, you just put it on the side or in the corner and the menu appears.
From memory, at least. Not used it in a while.
Posted : 02/05/2014 6:20 pm
I use classic shell, you can have a start button and use it like win 7. hardly ever see that metro rubbish now.
Edit: Classic shell is free to download and use.
Posted : 02/05/2014 6:30 pm
mmm...not permitted to install anything ๐Ÿ™
I won't die, sure I'll get used to it!
Posted : 02/05/2014 6:41 pm
Isn't there a button marked 'Desktop' on yours? Just click that.
Posted : 02/05/2014 6:56 pm
You must work for a company even more useless at implementing IT changes than ours!!
Ours won't touch W8 with a bargepole as the amount of user training would be silly, W7 Enterprise means all users have a fairly familiar interface.
Posted : 02/05/2014 7:52 pm
