[Closed] sun tubes / light pipes, any reccommendations?
Looking at fitting a sun tube thing for a dark area of the house, anyone got one / fitted one? Are there any best / worst makes?
Thanks
I had a 3 bed semi which I extended to the side to make it bigger, this meant I lost the window that gave daylight to the landing at the top of the stairs. I fitted a rigid sunpipe from Monodraught. It also has a light in this one so the area only has one diffuser/light.
It is very good at delivering daylight. I fitted it myself, the hardest bits are fitting the top dome in the roof and getting the rigid pipes to the correct lengths and to fit together.
Well worth the £250 ish I think I paid for it 7 years ago.
thanks, will look at them.
Do you notice any major heat loss / cold spots around them in winter?
With it being at the top of the stairs the heat will obviously move towards it. There is a loft hatch (insulated) and the sunpipe in the landing ceiling but no noticible heat loss.
The loft does have 300mm of insulation and my combined gas & and elec bill is £77/mth and thanks to the wood stove I am in credit despite the poor weather, so I would have noticed if it was cold.
With is being sealed at each end rapid heat loss would not be possible anyway. Bite the bullet, get it fitted.
