Stupid question abo...
[Closed] Stupid question about exercise and weight loss
and even worse, when the pseudoscioence is used to reinforce negative attitudes/habits on the basis that "my endocrine system isn't letting me do this"
That's probably well worth reinforcing.
To Solo and the weight-loss deniers, who seem adamant that it's basically impossible to lose weight and thrive while exercising at a 'deficit', how do you explain the physique of pretty much any endurance athlete?
For example, most runners in regular training, especially in marathon training, will lose weight (and some muscle mass, depending on cross training), regardless of what they eat. Building an endurance body requires many thousands of extra calories, but there's enough 'deficit' built in, especially in physical repair after first fuelling a run, that fat will be lost. Do you seriously think the 'endocrine system' is holding back runners doing 120 miles per week from losing weight? Do you think they lack the necessary energy to fuel their runs, even when they are in the process of getting lean for a target race?
It's not that people are all that different in their fuelling needs, it just depends on the level of training and the resultant level of adaptation to that training. The body will naturally learn to burn more fats and spare carbohydrate/glycogen the more you train your body through the repeated bout effect; that's just one adaptation to increasing exercise levels.
Spend most of your day on your feet/walking, and throw in some exercise, eat pretty much what you like, but aim for a largely Mediterranean type diet, avoid excess sugars from drink, and, unless you've got a metabolic disorder, you will likely continuously lose fat.
Posted : 25/08/2015 11:58 am
 Solo
[i] day to day it's really a matter of 'eat less move more' with a big side serving of MTFU[/i]
Eat less? How do you suggest someone does that? Fewer calories, perhaps? .... oh, wait a minute......
The suggestion to MTFU being made by someone trapped in a flawed and out dated paradigm is amusing.
Much more amusing than the patronising remarks about how Joe Public is too thick to understand what you know.
ELMM has an impressive history of totally failing to achieve its purpose.
But it allows those afflicted with a misplaced sense of superiority to admomish the "weak" and get a kick while doing so.
Alternatively, an intelligent person might question the wisdom of giving advice with such an ineffective history.
That's likely all the STW fun I can handle today.
Posted : 25/08/2015 12:16 pm
...That's likely all the STW fun I can handle today
back under your bridge then matey 😆
...Joe Public is too thick to understand what you know.
ably demonstrated by just about any thread here on losing weight or eating healthy 😛
...Eat less? How do you suggest someone does that?
ummmmm, maybe eat a smaller portion, just off the top of my head like 🙄
Posted : 25/08/2015 12:17 pm
Eating less and maintaining weight seems a contradiction to me unless there is a significant reduction in physical exertion. I must admit I'm sceptical.
There has got to be other factors which are not being measured. Little treats, snack etc.
I can see that various glandular problems etc could slow down weight loss, but effectively if less energy is going in that being expended, it's got to be impossible to gain weight without sundering several laws of physics - unless our method of measuring the energy capacity of some common foodstuffs is flawed.
Or could there be any truth in that Indian guy who claims to live on air? 🙂 (Breatharian?)
Posted : 25/08/2015 12:32 pm
One of the biggest issues I have with these threads is the amounts of backward reinforcement that goes on.
Molgrips is pretty much spot on here, what works for you might not work for him, I can live pretty much carb free (and I do) I see from his posts that would make his life intolerable, so while I'm happy enough, telling him (or worse dragging up any number of scientific papers on the subject) to reinforce my belief about what works to loose weight is a best unhelpful, and at worst counter productive.
ELMM might work for you, or calorie deficit, understand though that there as many ways to sustainable weight loss as there are ridiculous diet plans. Any new way of eating has to bring rewards and be maintainable, if you find one, great. But trying to tell others that their ideas are all wrong, and unscientific is pretty much pointless.
EDIT: I'd add that, I'm not saying that "your" lack of weight loss success isn't your fault...It generally is, but what I'd suggest is learn to look at ALL the information that coming out about weight loss strategies these days, and learn to adapt your thinking and ideas.
Posted : 25/08/2015 12:37 pm
From my own experience I don't agree with that. There is a significant adaptation to diet changes as well. Training is one half of the coin, diet is the other.
I was doing a fair amount of training - running 2-3 times a week, big ride on a sunday. mountain bike 2/3 times a week and circuit training. I never really looked at my diet but was always around the 75kg mark.
I decided to have a fitness test done because I wanted to have a go at racing and to see where i could improve
despite all that training my fat utilization was appalling. Right at the bottom of zone 2 (127bpm) I was only using 43% of my cals from fat
I then changed my diet (effectively followed the idave/four hour body diet) where ate a lot more eggs, no cereal and no high carbs. I re did the test after 5 months and that figure went from 43% to 84%. The trainer told me my body had become fat adapted ( I also dropped down to 68kg where i've stayed for the past 4 years)
Posted : 25/08/2015 1:00 pm
As above. Do you test tyre puncture resistance using a tyre that already has a puncture or a standard, correctly inflated tyre?
Conducting a which is best test on subjects who's bodies already suffer a distortion of normal function is a trick someone is trying to slide by the reader.
Just to clarify, this was a clinical trial, clinical in this instance meaning 'relating to the observation and treatment of actual patients'. It used people with a high BMI because obesity is one of the most far reaching and damaging health problems that we currently face, so it is important to help people like that to acheive a low BMI. It was not a sneaky trick to try and get one past the reader.
I think the confusion might lie with the fact that much of this thread has been concerned with people who are already reasonably or very fit and also reasonably slim endeavouring to get more fit and more slim, which is a great thing of course, and there is a lot of work that is being done in the sport science world that is entirely focussed on that which is also, obviously, great. But I feel that it seems a little rash to close our minds off to any studies that are carried out in the health science world, because it seems to me that there are times when the two very much overlap, with weight loss being a very good example.
I also feel that talking about tyres, punctured or otherwise, is a little misleading (although completely relevant to a bike forum, obvs 😉 ). There might well be a sound, physiological reason why someone with a high BMI will react to a specific diet differently to someone with either a low or a recommended BMI, so it might be more helpful to talk about that instead.
Posted : 25/08/2015 1:14 pm
Well said shermer
Posted : 25/08/2015 1:18 pm
trickydisco - Member
I don't dispute your experience, but frankly my assertion about fat burning and glycogen sparing is not really in question. This is what happens with training. It is also why a beginner runner can't go for a 5k run without then getting home and raiding the biscuits and bread (if they lack willpower), while a trained runner can go for a 10 mile tempo run on water alone.
It's quite possible you substituted foods that are significantly healthier and less calorific than others and therefore lost some weight. It's possible your training (type, intensity, duration) changed when you hired a personal trainer.
But these are not to dispute the physiological changes that occur with increasing your endurance training loads. All running, cycling and other endurance sports, contrary to popular belief, heart rate 'zones' etc., burn a combination of fats and carbs. Intensity alters the fuel source, but the after-effects usually balance out the resource output. E.g. HIIT will use carbs as fuel during, but, afterwards, raise the metabolic rate for hours to use more fats to restore equilibrium.
And whatever anyone asserts, personal trainer or otherwise, heart rate training cannot accurately and definitively predict your fat utilisation. But that's a different matter.
Further, I think we're on different wavelengths about bodily adaptation to fat input/output. You can, as you may have done, train your body through diet to use more fats than carbs (through adaptation to ketogenesis). But how a heart rate would predict this is entirely unclear.
Posted : 25/08/2015 1:33 pm
 Solo
[i]hilldodger - Member
But fundamentally, until you understand how energy is generated, stored, transported and utilised in biological systems you may as well stick to CICO /or "what works best for me" because all this half assed pseudoscience is going to get you nowhere[/i]
I your particular case, and in light of TrickyDisco's post. I agree 😉
A precis for Hilldodger:
[i] despite all that training my fat utilization was appalling.
The trainer told me my body had become fat adapted [/i]
It is what you eat, over how much. Type of cals over counting cals.
8)
Posted : 25/08/2015 1:56 pm
During a six-day race from Sydney to Melbourne, Yiannis Kouros was said to have managed to take in 15,000 calories the first day, 12,000 the next, and 7,000 the third day. During the Phidippides run that traced the Athenian messenger’s route from Athens to Sparta (and back) for a total of 300 miles, Kouros consumed half of his calories as Greek sweets, eating every 20 minutes, and enjoying baklava, fresh creamy custard, and honey cookies. He says he doesn’t eat too much fat, using mostly carbohydrates and only loses weight in races if he wants to, even gaining weight in some. "But food is not the secret. While you have to avoid making mistakes with food, the Australian runners documented what I ate one year in an ultra-distance race and copied it the next year and I still won by 28 hours."
http://www.runnersworld.com/trail-runner-profiles/on-the-trail-with-yiannis-kouros
This guy's taking in more than Tour de France riders to keep him fuelled. This shows how difficult it is to maintain caloric equilibrium when doing extreme endurance sports. Also, he's doing this on a strict vegetarian diet. Notice how he says he only gains weight if he wants to.
Posted : 25/08/2015 2:02 pm
...Type of cals over counting cals
you don't get calories from food unless you burn them in an oxygen rich environment to total ash and measure how many degrees celsius you have raised a given mass of water by.
Your (and many others) fundamental failure of interpretation and lack of understanding of what a calorie is, and how innapropriate it is to use as an energy unit in a discussion on metabolic energy, reduces everything else you say to just background noise really 😆
Posted : 25/08/2015 2:22 pm
When I lived in Oz, it was the norm to not feed our dogs 1 day in the week (obviously a rest day). This was to keep them fit and trim and their coats in good condition.
It seemed to work.
Now I wonder how good that would be for a human
... and whether my hair would regrow. 🙂
Posted : 27/08/2015 6:09 pm
Page 4 / 4
