Stud wall - easy wa...
[Closed] Stud wall - easy way of doing door&frames
I need to build an internal stud wall set of rooms - the problem is I hate the faff of hanging and messing with doors.
My googlefoo is lacking this afternoon - surely someone in this day and age does a pre assembled/complete/doorset/drop in pre hung door with hinges and latch thats ready to go in a stud wall???? Finished appearance isnt important.
there are these available at B&Q;
http://www.diy.com/departments/easy-fit-panelled-pre-painted-internal-door-kit-for-opening-sizes-w683-695mm-h1988-1996mm-d35mm/1016052_BQ.prd?icamp=recs&rrec=true
Not sure if anyone has used them? or has any other ideas?
Posted : 19/02/2017 5:59 pm
we call them pre-hung doors this side of the pond.
Available in our big box stores for either 2x4 or 2x6 framing. allows for 1/2 drywall too allowing door trim to be installed flush.
Posted : 19/02/2017 6:25 pm
I've just finished fitting eight frames and doors in a loft conversion, a ball ache of the highest order, a laser level makes things a bit easier.
Are the pre hung frames the correct width? as i had to rip down my frames to 120mm to fit the studding as this is not a standard width.
Posted : 19/02/2017 6:33 pm
my googlefoo is returning post hangover;
have found Premdoor Speedset plus
just need to figure the ordering codes and get a quote.
edited to add;
Ordering Quantities
Minimum order of ten doorsets applies.
bollox
Posted : 19/02/2017 6:47 pm
Hearing the phrase 'stud wall' just makes me think 'glory hole'...
Posted : 19/02/2017 7:57 pm
Bet your internet history is educational ๐Ÿ˜›
Posted : 19/02/2017 9:10 pm
[url= http://www.wickes.co.uk/Wickes-Internal-Cls-Sized-89mm-Softwood-Door-Lining-27-5-x-120mm-x-2-01m/p/146288 ]Wickes[/url]
(How do you end up at 120mm, anyway?)
Posted : 19/02/2017 10:28 pm
 km79
Pre-hung door sets are not really commonly available for the UK DIY market. They tend to be specially ordered for large developments and the like.
Edit: You might be able to find someone who can order you these, I think they are made to order though so might have a large minimum quantity.
Posted : 19/02/2017 10:39 pm
ask the local builders merchant or joiners shop to hang a standard door into a lining for you?
we used to do this to save time on site when doing overnight shopfitting.
and a 6ft level makes fitting linings easy. but using lasers means you can charge more ๐Ÿ™‚
Posted : 19/02/2017 11:09 pm
