I've just run out of strimmer line, which was probably too lightweight for the size/output of my machine. I've googled it and cant find an answer. What size line should I use for a 40cc strimmer?
Posted : 27/07/2009 8:12 pm
RTFM
Posted : 27/07/2009 10:52 pm
RTFM?
Posted : 27/07/2009 11:01 pm
G is being a bit abrupt, and is suggesting that you 'Read The F-ing Manual'.
However, I can save you the bother. I use 2.5mm line in my 30cc strimmer. 3.00mm line will see you fine. You can also buy square section stuff- it's brilliant.
Posted : 27/07/2009 11:27 pm
Thanks Ambrose. The line I was using was 2.8mm. I've got a jungle of nettles to clear. So I'll give the 3.00mm stuff a try.
G, I didn't get a manual with it. OIHFRI
Posted : 27/07/2009 11:39 pm
mmmm - the finer points of strimmer mm size versus the cc size of the strimmer
fascinating!
