Strange dripping ta...
[Closed] Strange dripping tap problem
Mixer tap in en-suite has been dripping
Latest development is that the tap whistles when hot water is used elsewhere in the house - this carries on for a few minutes each time
Also seems to be dripping hot water when it whistles, even though tap is set to cold position
Posted : 28/05/2014 12:17 pm
what tune is it whistling.
Posted : 28/05/2014 12:45 pm
Titanic theme tune
Posted : 28/05/2014 12:46 pm
Might be a backflow problem with the mixer tap. Changes/differential in pressure allowing water back up either hot or cold from the other supply?
Check valves on each supply to the mixer would fix it.
Posted : 28/05/2014 1:32 pm
