My windows stick shut and i have to up/down/up/down them to free them first thing what can i coat the tops with to stop this, i thought oil would just rub off?
Posted : 19/11/2013 11:06 am
On customers cars in winter, I spray a bit of silicone lube in the gap the window closes into to prevent this.
If you don't have that, some dash dressing or other silicone based stuff will work.
Posted : 19/11/2013 11:10 am
Silicon lube is useful and you can get it cheap enough from Halfords.
Posted : 19/11/2013 11:17 am
Might be worth checking the window regulator mechanism to make sure that the window hasn't developed play causing it to drag and / or catch as you operate it.
Put the window down, take hold of the top and see if you can move it side to side.
Posted : 19/11/2013 11:36 am
cheers all will do.
Posted : 19/11/2013 1:02 pm
