Stepped drill bit? ...
[Closed] Stepped drill bit? very big sizes...? anyone know where to get one?
For sheet metal? I need a hole of 80, so a bit that does 40, 60 & 80?
or can this be made custom?
Posted : 06/12/2017 7:35 am
How accurate does it need to be? You could use an 80mm hole saw. Or a 79mm and tidy with a round file.
Hole saws tend to mark the edge of the hole as they enter the material.
Posted : 06/12/2017 7:42 am
its to go through the floor under the seat on the T6 for the heating duct to come through. The thing is there is already a hole there from origin about 40 i'd say so was hoping to just enlarge this (its just for cables, but not used). not sure if a hole saw would be ideal as centering would be tricky..
sorry, so to answer the question not very accurate!
Posted : 06/12/2017 7:44 am
Tack weld a small strip of steel across the hole then you can use a holesaw with centre drill.
Posted : 06/12/2017 8:07 am
Definitely sounds like a job for a hole saw. Just need to temporarily add something for the centre drill to drill into. A bit of plywood will do it.
Posted : 06/12/2017 8:10 am
If you go with hole saws you may be able to do this (depending on which arbor you have) screw the smaller one on into the large one. It acts a giant pilot. It’s easy to get an egg shaped hole and scratch the metal up with the wrong size pilots! Puts a lot of tourque on the drill with large hole saws! You can ruin the clutch on the drill.
Posted : 06/12/2017 8:22 am
 eemy
If you take some time to build a robot, enter and win Robot Wars, then the trophy has a suggestively large drill bit attached to it.
[url= https://s2.postimg.org/8q2ttblmd/Robotwars.pn g" target="_blank">https://s2.postimg.org/8q2ttblmd/Robotwars.pn g"/> [/img][/url]
Posted : 06/12/2017 8:34 am
A method I have used with success on larger holes but which would probably be fine for this. Scribe the hole. Using say a 4mm drill bit, drill a ring of holes 1mm in from the edge of the hole and 1mm apart from each other. Then enlarge each hole carefully with a 6mm bit. You then need to file the peaks off all the way round, but if you are using a grommet/flange for the hole it doesn't need to be that perfect I guess.
Posted : 06/12/2017 8:35 am
Yip, chain drill or dremel.
Posted : 06/12/2017 8:39 am
ok i'll try that! thanks for the tips.
Posted : 06/12/2017 8:43 am
Get a sheet metal punch - far simpler, faster and neater.
Piece on either side, do up the bolt.
Simple.
[url= https://www.google.co.uk/search?q=80mm+sheet+metal+punch&ie=UTF-8&oe=UTF-8&hl=en-gb&client=safari&dlnr=1&sei=faQnWpqYAY_JwQKit6SYCg ]This[/url]
Posted : 06/12/2017 9:05 am
Put the holesaw through some scrap wood, say 18mm ply, then use the wood as a guide for cutting the finished hole, no need for centering.
Posted : 06/12/2017 9:28 am
Do as mrdoberman said, that's the way I always do it.
With the larger type arbor you are able to screw 2 holesaws onto it at the same time!
Posted : 06/12/2017 11:15 am
