Stainless steel tri...
[Closed] Stainless steel triple wall sockets?
I am running out of wall sockets in the kitchen (too many gadgets). However I do not fancy chasing out new sockets as the walls have been tiled over. I was thinking about replacing the double gangs with triples but cannot find any - is there any available???
MUST be stainless steel to match the rest of the kitchen.
Posted : 08/07/2009 12:39 pm
 -m-
If you're planning to swap a (flush) double for a (flush) triple, then presumably you're anticipating having to dig out for a larger pattress box? In which case, couldn't you just dig it out slightly larger to put in a second double next to the first? If you butted them up tight, and were careful when you cut the tiles, it would look OK visually.
Posted : 08/07/2009 1:11 pm
I think he'd be in trouple with par P (or whatever part it is) regs?
Posted : 08/07/2009 1:15 pm
 -m-
In theory wouldn't you be in trouble anyway - aren't kitchens and bathrooms total 'no go' areas under Part P?
Posted : 08/07/2009 1:17 pm
That would be the option but I think it would look naff.
No because I 'did' it before the regs changed (ahem).
Posted : 08/07/2009 1:20 pm
I bought some s/s (stainless steel, not singlespeed) sockets recently for some re-decorating. I can't remember seeing triple ones anywhere though.
Sorry to be no help at all.
Posted : 08/07/2009 1:23 pm
 -m-
๐Ÿ˜€
I've lived in several houses that have had faceplates butted together (sockets against cooker switches, sockets against switches for under-cupboard lighting etc) above the worktops in the kitchen. Generally it looks OK - I'm not sure that two adjacent doubles is much more odd/unusual looking than having a triple...
Yeah you are possibly right - I might just get another double and pop it up next to it...
Posted : 08/07/2009 1:27 pm
 -m-
Unfortunately I think it may be your only real option - not sure I've ever seen a stainless triple socket.
Good luck preserving the tiles...
Posted : 08/07/2009 1:30 pm
That is the worry...
Posted : 08/07/2009 1:34 pm
