Community
** Sounds the STW E...
[Closed] ** Sounds the STW Excel Experts klaxon **
Dynamic Excel Filter Search Box.
I've managed to do one of these on one sheet using raw data from another.
How do I create a second box on the same sheet please? I'd like to have a few of these boxes so users can type/select above the column they know some detail for eg part of a document name or the category its in.
I've repeated steps I took for the first box using new helper columns. I'm at the stage where I typed and copied the final formula across all cells in the user sheet. I don't know how to do this last bit as surely I'd overwrite the existing formula?
Formula in question is:
IFERROR(INDEX(Sheet1!$A$12:Sheet1!$N$323,Sheet1!$R12,COLUMNS($A$6:A6)),"")
Thanks
Posted : 03/09/2019 1:04 pm
Should I just have one box and adjust the formula so folk can type into it to search under document name or category or doc number etc?
Posted : 03/09/2019 1:13 pm
Off topic, but what other STW klaxons are there?
Posted : 03/09/2019 1:15 pm
There's a mortgage klaxon, a savings klaxon, a business class klaxon just to name a few.
Posted : 03/09/2019 1:16 pm
Dumb question - but couldn't you use slicers instead?
Posted : 03/09/2019 1:20 pm
Dumb question – but couldn’t you use slicers instead?
They don't make the right noise - it has to be a klaxon
Posted : 03/09/2019 2:21 pm
