Solar panel payback...
[Closed] Solar panel payback on this year's FITs?
What sort of FIT payments are people getting from system that were installed this year? How does in compare to what you were told it would be?
I know that the FIT has gone down a lot but with rising energy prices I'm looking at getting some panels on the roof. I will be financing it through a 5 year low interest loan. According to the figures on an installers website during the loan I shall be paying out about £20 a month but after that I shall be getting about £50 if the figures are correct.
The panels would be split between a SE and SW facing roof in East Anglia so sunshine hours are some of the highest in the UK.
Posted : 15/11/2013 2:13 pm
On domestic sized roofs you should be paying £1,600 to £1,800 / kW installed. If you do that and use a good quality, respected installer, you will still get a good return from an unshaded south facing roof.
Posted : 15/11/2013 3:05 pm
I wouldn't be doing it on finance.
I had my 2.25kW system installed on Sept 21st. By Nov 12th (52 days) it had earned £55; that's £32 FIT payment, £5 for leccy sold to the grid and £18 of leccy use 'avoided' (assuming I've used/sold 50% of the leccy).
Bearing in mind that this is during Autumn and therefore dwindling daylight I'm confident that this is on-target for the estimate I was given for an annual generation figure. In fact the evidence points to the system being able to exceed the estimate by around 10% if it's a good year.
Can't imagine getting £50 a month - that's a lot of generating going on!
Posted : 15/11/2013 3:48 pm
Their actual calcs state £900pa in savings+FIT+export based on a 4kw setup but this assume you use 75% where as actually it's likely to be 50% or less.
Posted : 15/11/2013 4:28 pm
4kw...must be a big roof...
Posted : 15/11/2013 5:33 pm
Christ! £900 per annum PLUS FIT!!!!!!
I think that is probably a bit optimistic........
My system is forecast to do 2000kW per annum, equating to 490 per year TOTAL.
Posted : 15/11/2013 7:13 pm
