Community
Snorkel masks, can ...
[Closed] Snorkel masks, can anyone recommend one please
One for me, one for my daughter.
We're off on hols over Christmas and hoping to do a bit of snorkelling. Got snorkels but no masks.
Well only be mincing around in the sea, nothing too serious, weather permitting of course.
Posted : 07/12/2014 9:59 pm
Ideally get to a shop and try some on. Fit is the main thing
Posted : 07/12/2014 10:20 pm
^ what he said. Try some on in a shop. Put the strap round to the front of the mask, and push the mask against your face. Inhale through your nose, the mask should 'suck' to your face, and will stay there without you using your hands, while you turn your head, look down etc. If you can't maintain the vacuum and it falls off, it doesn't fit and will likely leak when you're in the water.
After that, pick one that suits your budget, feels like it has a good viewing angle (i.e. you don't feel like the frame is taking up too much of the view, is a nice colour, etc.
Posted : 07/12/2014 10:30 pm
As above for fit but once you have got one clean the inside of mask with a small amount of toothpaste to remove the coating on the glass or the mask will keep fogging up.
Posted : 07/12/2014 10:36 pm
I got a mask & snorkel in Spain that cost 18 Euros in a 'kit'. Works fine!
Posted : 07/12/2014 10:37 pm
because everyone's face is a different shape, we all fit masks differently so try them out - decathlon have loads
put the mask on your face without the strap on your head, suck in with your nose and it should sit on comfortably
shaving improves the seal
the only bit of advice I remember is that guys with broken noses should avoid tusa pano geo because the plastic frame presses on your nose bridge and causes bruising...
Posted : 07/12/2014 10:51 pm
I started out with Decathlon masks, as it was on a trip to France when I was in the Cubs that I took up snorkelling, and I had my first experience of Decathlon. Good kit at good prices. Currently using an Apeks Quadra Tech which fits me well and has good visibility to the sides
Posted : 07/12/2014 11:02 pm
If all you're doing is snorkeling Decathlon stuff is fine - but as mentioned above fit is the most important thing. It's worth getting some fins (flippers) too, while you're at it.
Posted : 08/12/2014 12:14 am
Decathlon for us as well, good kit, fits well, good price.
Posted : 08/12/2014 9:47 am
