Small Windscreen Im...
[Closed] Small Windscreen Impact / Crack.......Repair ?
small indent on front of windscreen, 7mm crescent shaped crack......
about 14cm from centre bottom of windscreen....
repairable ?
TIA
Posted : 12/08/2012 5:22 pm
DOn't think so, they can usually repair a chip by filling it with resin, they can't get the resin into the crack (I could be wrong).
Had the same thing happen to me a couple of weeks ago, the crack got rapidly bigger over a couple of days whilst waiting for the replacement windscreen. luckily it was outside the main vision area.
Posted : 12/08/2012 6:30 pm
as above, cracks are replace time.
Also just went through it myself. Hadn't noticed a chip of around 1mm until suddenly there was a 4inch crack in the screen. Easily sorted through insurance though, £75, half an hour's work and half an hour cure time
Posted : 12/08/2012 7:31 pm
7mm should repair surely. Got to be worth a try. I got a DIY kit for my van, (2nd crack about 1 month after replacement, 😡 ) as it was right over on the left hand edge. Drilled a couple of little holes with a tile/glass drill and started at that end. Not a perfect job, but it's not getting any bigger now.
Posted : 12/08/2012 8:43 pm
