[Closed] SketchUp/SketchUp Pro line weight
I'm sure I could change lineweight to something like 1 or 0.25 in SU pro but is his possible in standard SU. I thought it was changed in styles or perhaps document/page setup but i can't find it well i can't even find document setup at the mo. confused ๐
Posted : 05/11/2009 10:27 pm
From hazy memory
Window>Styles then click the "edit" button in the Styles menu?
Its the thickness of the 'Profiles' under the edit section varies the line weight I think. Then farting about with the resolution when you export jpegs effectively varies the line weight too.
Posted : 05/11/2009 11:42 pm
