[Closed] Simple Photoshop CS5 question...
I open a .jpg file and edit it, then when I click "save" I have to:
a) select .jpg not .psd (the default)
b) click 'save'
c) confirm I want to overwrite existing file
d) click OK for quality/format
e) confirm I don't want to save it [b]again[/b] when I try to close it
isn't there a way to condense all that into one 'save' click ?
barnes........you ok.
not seen or heared from you for a while.
That's because he's been playing with CS5! 😀
Spensive...
ctrl/S maybe ?
write an action?
Mmmmm multiple edits to JPGs?
One way to ensure you lose quality and gain compression artifacts.
Sorry, nothing helpful to add, not [s]downloaded[/s] legitimately paid for it yet. 🙂
Heh!
no, a single complete edit 🙂
Sorry, nothing helpful to add, not downloaded legitimately paid for it yet.
I'm still working with the trial download, having resisted Adobe software for the last decade 🙂
You adding layers? On older versions of PS that's a sure way to make it default to .psd.
As for asking you whether you want to overwrite existing file... better it does than not! If you ever accidentally save over half a day's work you'll understand.
Are you editing and optimising bottoms, Simon?
I disagree, I have the raw files saved as originals, and if I had intermediaries I'd save those separately. I don't want a program asking me if I want to do what I've just told it to do 100 times a day.
And yes, I'm using layers, which is the recommended method now.
... there might be a few 🙂
you can't save layers with a jpeg?
why not just save-as (ctrl shift-S) and give the edited image another name. then don't save when closing the image.
Jpg as a format doesn't cope with layers. Flatten your image (shift+command+e) first and it won't ask you all the questions.
tersliiiiide!
Eh?
If you're opening a JPG, changing it and then re-saving it then you'll be introducing compression artifacts and losing quality.
It's still a multiple edit because it has been saved more than one.
OK, but if I'm then posting it on the web then I hardly care, do I ?
thanks, but it still asks me about the level of compression every time 🙁
write an action then or is the 'save for web' command still in cs5? (not upgraded yet)
I disagree, I have the raw files saved as originals, and if I had intermediaries I'd save those separately. I don't want a program asking me if I want to do what I've just told it to do 100 times a day.And yes, I'm using layers, which is the recommended method now.
Just re-read that. If you know best, why exactly are you asking for help? 🙄
If you don't want separate versions, fine, but you'll have to sacrifice the future edit/undoability (and quality) that comes from keeping at least one layered psd.
Compression level should persist according to whatever you last chose when you saved something, so if you don't care too much, you only need to hit 'return' when it asks you. Too busy to extend your right pinkie for 1/4 of a second?
What LuckyJim said.
because I want the program to do what I tell it, is that too much to ask ? I'm used to 'save' meaning save, not umpteen confirmations
not when I have to do it 100 times. I want it to remember my choice and not ask again until I tell it I want to change it. Dialogs you always click through are an elementary user interface gaffe, they don't actually offer any safety because you stop reading them 🙁
As for "save to web", every time I select that it warns me I may run out of memory (on a 6GB machine) and asks me to click OK with no option not to tell me again. Grrrr!
Now I want to crop a 225x150 pixel thumbnail, but as I drag the marquee there's no indication of the crop size 🙁
Crop size is shown in the info window.
jpg will need recompressing everytime you alter/save the image.
6gb ram is a fair chunk, how much free space on the drive, photoshop uses the ram available then the hd space as memory after that.
hth
Are you on 64-bit OS with 64-bit Photoshop?
If so then I can't see why it'd be short on memory unless you have something else huge open.
Think Photoshop lite might be the answer for you, takes all the grown ups stuff out of the equation 😉
yes, so I only do it once 🙂
695GB
yes 🙂
I need maximum power Igor:) What I don't expect is elementary user interface faults in software which costs over £600 a pop!
Whenever trying to save a high-res image via the save to web option, it will come up with a warning message.
In theory, I would resize the image to a sensible pixel size before saving as an optimised image via save for web. Otherwise you can save as a standard jpg via file>save as, without the warning in file>save for web.
Overall it sounds like an automated action would be the best process.
To do this open up the Actions window. Create a new action. Then go through the resize/save process you have been having to do each time (it is recording what you are doing). When done, click the stop button. This should automate the process into a one-click job, unless you have specific requirements for each image.
Any use?
Lol - fair enough. Guess the reason is you won't always want to use the same compression settings on each image you open and save. As has been said, you could set up a default action that will override all the clicks. Never bothered me. Cs5 (think it equates to pshop 12 or 13?) is pretty incredible. Been using it since 2.5 when there wasn't even layers! That made things interesting, working with multiple files open to copy and paste on a machine with **** all ram or disk space!
as i and others have said "write an action"
it does sound as though you would be better off with aperture/lightroom/photoshop for novices/gimp if all you are doing is resizing/cropping and working on 8 bit jpegs.
failing that pay Adobe a few million pounds to write you a custom app.
SFB we're sorry, you are correct... PhotoShop is widely acknowledged to be very very poor indeed. 🙄
Those
have been painstakingly developed over 20 years and are industry-standard. Perhaps you should allow your trial copy to expire and think about alternatives.elementary user interface faults
Do you apply the same awesome rationale to all things new... wade in with the criticisms without even trying to learn for yourself - or think about why things may have been done a certain way?
Useful answers have been offered. As has been said, RTFM and set up an action if a 25 second investment to save 100 files is too much.
"Save for web" comes up with a warning because (above a certain size of image), you are trying to use the function for a purpose it is not designed for. It's an optimisation tool. I would suggest that if you've not yet got to grips with the fundamental difference between a .jpg and a .psd you are not really ready to touch on this. Walk before you run. How about you stick your nose in a tutorial for half an hour and learn something?
It comes across as extremely rude to ask for help then pooh-pooh the responses you know.
+1 LuckyJim.
In my experience, whenever an engineer starts talking about 'user interface gaffes', you know it's time to start banging your head on the desk.
MTFU and press the keyboard 100 times 😉 🙂
you can create an action to do it. do that.
Should be 'Simple Simon's Photoshop question'...
Photoshop is rubbish. That's why the industry hasn't been using it for the last 20 years, and have been using MS Paint instead.... 😉
Happy Bottom Optimising!
I'm not saying that, but I'm amazed to find so many things so badly implemented - for instance, many of the tools forget their last setting - when it's reasonable to suppose the consecutive shots might well need at least similar corrections
no sorry, for a start industry standard doesn't imply good, but isn't this actually industry standard from 20 years ago ? And it looks more like negligence than painstaking!
to save a file ?? What are programmers for ?
photoshop obviously isn't for you. and perhaps beyond your rudimentary computer skills, patience and learning ability.
Maybe you are better off spending your £600 elsewhere?
Maybe use it to get a man in to operate CS5 for him?
or spend it in Hamleys or Toys'R'Us?
might it not be that I'm a professional programmer of 25 years experience unwilling to be fobbed off with antiquated design ?
I've bought it, and I'll use it for the scope of the tools, but it just confirms what I've always thought about Adobe software in that they are clueless about the UI
well i use it every day and i'm trying to think of things that annoy me about it?
i hate the way the screen jumps when i change the blending mode of a tool with a shortcut. it's almost as if it's redrawing the screen in for no particular reason?
the HDR (non tonemapped) implementation is crap. (sorted for CS5 though)
having to click out of a layer to get a true histogram generated. i appreciate this is process intensive but maybe it could be done in the background?
i don't like how the patch tool works at the edge of an image because there is no info to sample so it always ends up with brighter areas.
these are minor irritations and compared to what the software does well (stitching, colour correction in various different subtle ways,different ways of masking, non linear history, smart objects, etc etc) i wouldn't really change it. but then I'm a photographer not a programmer or computer geek.
Um, make your mind up.
Write something better then. Oh, didn't think so.
Have you tried Paint?
I tried the stitching, and it was rubbish 🙁 The horizon came out curved.
I also notice that .psd & dng files come up as black rectangles in Windows Explorer as Adobe haven't got round to writing a 64 bit codec yet...
I'm convinced it's got excellent tools and facilities (apart from the primitive stitching) which I look forward to learning how to exploit!
The only reason to upgrade to CS5 is content aware fill - and it is bloody marvellous.
simon: give CaptureNX a try. If you're working with Nikon NEFs (as I think you are) then you won't get a better quality output, plus it is lossless, and if you want to apply the same corrections to multiple photos you can just copy the settings from one and apply them to as many as you like.
I tried the stitching, and it was rubbish The horizon came out curved.
there are different ways of stiching (reposition only/automatic/perspective correction/etc.) never had any problems.
but surely the preview file embedded (just a small jpeg) will show up? or failing that use bridge.
i don't use bridge as i'm only working on one image at a time and process in capture one. wasn't a fan of it but it's very quick in generating previews and swapping between photoshop.
it is a steep learning curve. there is so much it can do, i guess i only really use 40% of it's capabilities and no matter how much you know about it other photographers/retouchers often show you something you didn't realise it could do.
if you are only resizing/cleanup/basic corrections and have an image database to maintain then Lightroom is very popular (not used it myself as i dont shoot volume and prefer to stick with CS5/capture one/hydra/bracketeer
thanks! I'd forgotten about that as it didn't work on my previous computer...
Well worth buying a copy of autoloader;
[url= http://www.photoshoptools.ca/ ]Autoloader[/url]
A beautifully simple little prog. All you do is point it at the directory of your original files, press F1, it opens the first file, you work on it to your heart's content. Press F1 again, it saves it according to your own parameters into whatever folder you specify and the next file opens on your screen.
Repeat ad infinitum, or until your directory is finished.
It's a great tool for working on a large number of pics and the guy who wrote it (Mike) has just sent me the new script for CS5 (I bought it four years ago) so ongoing support is a given.
The best thing is you can automatically run an action on every file (i.e., save for web at whatever quality) which sounds like it's perfect for your needs. Drop me an email if you've any questions...
Good god man save an ACTION to make it do the work for you. Or use the Image Processor script.
thanks, I've just been reading up on it, but doesn't it beg the question "Why doesn't PS do this itself?" 🙂
I think it's reasonable to suppose that if one has to create a macro to save a file the application is deeply flawed 🙂
Are you really this much of a tool in real life or is it just an internet persona?
Photoshop is the greatest invention since photography itself, imo. It's absolutely ****ing amazing, and I've been playing with it since version 1.
I probably use less than 10% of it's capabilities. What you can achieve with it is incredible.
But of course it's rubbish because Barnes can't save a file propperly or something... 🙄
FFS Barnes; sort yerself out man.
look who's talking 🙂
It's very funny to see people leaping to defend outdated programming which is incidental to the function or main design of the product. if it were cheap then such oversights and careless practices would be easily forgiven, but cheap it ent.
Yeah but there's no 'ope for me; you at least may have some chance..
How's the Bottom Optimising coming along?
Photoshop doesn't do it itself because if it did it would make it easy to accidentally throw away vital data (layers etc). Which is why any sensible professional would keep the layered Photoshop file and use the built-in save for web feature to export another copy for the web. Which is why you have to choose. Which can be a pain in the arse. Which is why Photoshop lets you set an action. Which is what several people have told you repeatedly.
Uber powerful professional software in a bit-complicated-for-amateurs shocker.
Heh heh!
which is the wrong way to do it. Rather than assume I'm clueless, by all means have the warning one time, but allow me to check "don't tell me again" if I choose to override it. Patching it over with a macro as suggested is a gaffer tape approach.
The proper way to avoid "accidental" loss of data or modifications is to save it all in a big undo buffer so you can go back later if you change your mind, rather than endlessly nagging the user.
Not.
No-one who understands and uses Photoshop all the time would ever set it the other way round. The default has to be to preserve data. If you want the default to be to chuck data away the assumption that you're clueless is correct!
ha ha, funny joke. I hardly thing one can describe fatuous warning dialogs (cf Windows 1.0) as "powerful professional" 🙂 And while I may be an amateur photographer, I am a programmer, so I do understand how these things work...
That's the point - they're not fatuous warnings. Not only is the software trying to make a critical point but it is also fitted with a very good tool (actions) to avoid it if you want. Everything you need Photoshop to be is already in there, you're just not using it right.
utterly wrong. I am confident enough in my workflow not to close a file until after I've finished with it, and don't appreciate silly handholding
Ok, so I've just tried this:
Open jpg file (just something off tinternet)
Do some squiggles
Cmnd-S
Close.
(CS3, Mac)
Simples.
Can't see why you're having problems, Barnes, unless you're adding layers. And if you are, then you need to Save As .psd file, 'cos jpg can't do layers. So, you're creating a whole new file.
Tell me again why Photoshop is faulty?
You can even set the action to save the layered file, which you can always go back to without losing fidelity, [i]and[/i] a flat jpg copy at whatever settings you like (with an option to pause at that point for you to fine-tune the compression to suit the content of the image) - all in one action. There are no circumstances under which that isn't a superior solution if you are talking about lots of files. Your way will burn bridges and no matter what your level of general competence with computers you will make a mistake one day that you won't be able to back-track on without digging back to the orignal file, if you still ave an unedited copy of it.
yes, adjustment layers, like they tell you to - a useful implementational metaphor and nothing more, except perhaps an elaboration of the undo mechanism, but not supported by display devices so flattening has to happen sooner or later.
it's not an acceptable compromise to slug every edit to avoid the slight risk of a mistake some time, particularly when my normal workflow of horizon, crop, histogram, shadows and highlights is nothing I need to preserve forever. If Adobe were serious about alieviating mistakes of that kind they could just store a description of all modifications in a small file associated with the image and perhaps delete them a year later. Getting the user to do the programmers' job is negligent.
I kind of agree with glenp there simon.
To me jpg is an output format, the equivalent of a print. Something I would only ever produce at the end of working on a photo, and then only as an export from the original 'negative' (NEF or PSD).
I can't think of many situations where I'd want to start from a JPG, spend time adding layers, then throw that away by flattening it into a JPG again.
Anyway, did you try CaptureNX yet?
Non-destructive, versionable editing of NEFs with full data from the camera, and batch correction and conversion of multiple shots. Plus it's about £500 cheaper. I rarely touch Photoshop thesr days.
Which is exactly what CaptureNX does, except that it is stored directly in the NEF with the image.
When you save a file to a format that does not support some of the features you have used, such as layers in a jpg, Photoshop saves a copy.
If not it would have to flattern the file you have open.
Hence you get the repeat question in your work flow.
e) confirm I don't want to save it again when I try to close it
If you flattern the open file so it is supported by the format you want to save as you will not have this problem.
Obviously it will still ask you for the quality settings but why would it not?
because it's brain dead ? I'd far prefer to tell it when I want to [b]change[/b] the quality (if ever) not every bloody time I don't 🙂 Unless I'm saving for web (which is also broken) I always want max quality, and I have 5TB of spinning disc to hold it 🙂
max quality
Stop using JPG then!
Bring back film, scalpels and cow gum 🙂
At least you could snooze in the dark room
Am I missing something here? You don't use Photoshop all the time, or professionally. So you ask why it works in a certain way. And then lots of nice people (well, plus me) give you nice sensible answers. And then you're still pissing.
The answer is if you don't want a layered file, don't create one. Just use the adjustment tools in their direct way, all of which have keyboard shortcuts, and then save, which also has a shortcut.
Crap way of doing it, but if you want quick and direct then its right for you, esp since you seem so confident you won't have to go back. Personally I'd use levels and curves adjustment layers so that I could go back into them and fine-tune if needed, for example if your expected result when served on a web page is not quite right.
The problem is that you are using the power of layers when you don't want to. So don't. To be honest, your question is plain daft. No-one is forcing you to make layers, just edit away if you're not going to keep a safety.
oh, to suit some numpty in San Jose I have to change my file formats ?? Do [b]any[/b] web browsers support .psd files ?
because it's brain dead ? I'd far prefer to tell it when I want to change the quality (if ever) not every bloody time I don't Unless I'm saving for web (which is also broken) I always want max quality, and I have 5TB of spinning disc to hold it
(a)When creating a new file (including copies) it asks for the quality you would like to save as.
(b)When saving changes to an existing file you are not asked to select quality settings again.
Photoshop asumes that in (a) you may not want to use the settings of the last file you used and in (b) that the quality settings you chose when first creating this file still stand. This makes perfect sense does it not?
oh, to suit some numpty in San Jose I have to change my file formats ?? Do any web browsers support .psd files ?
Why are you using "save as" for jpg's to use on the web? and
is not an answer. I use it everyday so it's not."save for web is always broken
This actually suggests a case of user error / lack of understanding. Try keeping all you files as psd's and then use Bridge to batch convert any you need for the web to the correct format in nice small file sizes.
I wasn't, I tried "save for web" at someone's suggestion
every time I use it it complains about the image being too big and says it may run out of memory. The only time it didn't was when I'd cropped part of an image and shrunk it to 1000 pixels high. My PC has huge amounts of memory, disc and CPU.
Are you being deliberately obtuse now simon?
PSD is [u]the[/u] photoshop file format. The fact that JPG cannot support layers and uses lossy compression is down to the JPG file format and nothing to do with any numpty in San Jose.
No, no browsers support PSD. But you just said yourself that you always save at 100% quality (as near lossless as possible with JPG) because you want max quality.
My point is that if you are worried about quality then those saves should be to PSD and you only export a JPG version at the end when you're done. That way you also benefit from those non-destructive layers you are carefully adding.
I want it to use the same for all of them unless told otherwise, asking every time is dumbass.
Fair enough.
Not heared of that before. out of interest how big are the original images? i've "saved for web" from images up to about 150mb but not larger.
Did you understand my post about flatterning the image before saving as this will solve the problem from your OP.
A masterpiece of trolling SFB... you've spun a boring non-thread into an 80-odd respose ego fest and willy-wave session. OK, I'll bite some more.
Here's an allegory for you. I hate spell-checkers. I hate them because they think they know best. They try to 'correct' my spelling on-the-fly, though not against a dictionary that I have chosen, or ever would choose. They underline words or phrases in hideous colours (or should that be colors (no it shouldn't)) simply beacuse they don't recognise them. They get arsey about syntax if sentence structure begins to stray above Janet-and-John levels of technical competence...
Photoshop is the opposite. It is a blank canvas. It doesn't tell, it [i]asks[/i] me what I want to do. It trusts my judgement. It expects me to know the difference between .png, .gif, .jpg, .tif, .psd etc. etc. It won't interefere with my decisions unless I am in danger of discarding data or doing something nonsensical. In short, it assumes I am an expert. I want something to happen, I make it happen. End of.
MS Office, for example, is a wretched piece of dreck beacuse in trying to be helpful it actually hinders creativity and wastes system resources. PS's philosophy is massively better because it provides a toolkit to do whatever the hell one wants and only asks "are you sure?" when trying to step outside a few common-sense parameters.
As a supposedly free-wheelin', free-thinkin' free spirit, who claims to have some technical nous, I would have assumed the latter philosophy would be far more attractive to you.
As above, try Lightroom or Aperture. They should fit under the trolling bridge somwhat better. Shoot in RAW, maintain your edit settings as text attachments and save .jpgs to your heart's content.
You may be a programmer, but airing your view that PS is poor software design anywhere - and I mean [i]any[/i]where - and you will get laughed out of there.
God knows why I am sticking up for it. Adobe certainly doesn't need me to do that.
