Showing laptop disp...
[Closed] Showing laptop display on TV - help please
Is there anyway of getting my laptop to display on a normal HDTV? I want to watch iPlayer stuff on the TV instead of the laptop.
Posted : 29/01/2009 6:04 pm
S video output on the laptop? bout all i can suggest unless you've a DV camera with an S video output to act as a converter.
Posted : 29/01/2009 6:06 pm
What do you mean by 'normal' HDTV? The last two I bought both had a VGA socket. I geuss yours doesn't or you wouldn't be asking.
Some laptops have TV out. Usually S video, which is usually a small round, yellow, 4 pin socket.
Failing that you can get a convertor, either usb or vga to TV out. PC world sell them or they are much cheaper on-line.
Posted : 29/01/2009 6:09 pm
I have an external monitor socket, a mic socket, a headphones socket, a network socket and some USBs. It is a Lenovo R61i if that helps.
Posted : 29/01/2009 6:25 pm
It also has s-video out so use that.
Posted : 29/01/2009 6:28 pm
Use a VGA lead between the external monitor socket and the VGA in on the TV. Same type of socket as the external monitor one on your lappy.
I had to mess around a little and set my laptop up so it treated the TV (external monitor) as its primary display otherwise when I shut the lid the TV went blank.
You'll also want a 3.5mm stereo jack to phono connections for your sound. iPlayer (standard quality) is perfectly watchable on a 32" screen ๐Ÿ™‚
Posted : 29/01/2009 7:35 pm
Oh, had to mess around with the resolution for the primary display as well...I found 1280x768 gave me a full widescreen image without stretching/black bars (I think - can't check that as gf has control of the remote at the moment ๐Ÿ˜‰ )
Posted : 29/01/2009 7:37 pm
