Shed lighting - sol...
[Closed] Shed lighting - solar panel?
Running electrics to my small workshop/ shed is not possible.
Anyone used a solar panel / renewable energy source for power?
Experiences : suggestions
Posted : 08/07/2013 9:49 pm
Easiest and cheapest would be a 12v car battery and a trolley to take it inside and charge up.
It will probably cope with two or three weeks if you are just using it with some 12v camping strip lights/LEDs.
Solar panels will up the cost quite a bit unless you are just thinking of a tiny battery saver type thing that is designed to go on a car dashboard.
Posted : 08/07/2013 10:37 pm
How much power do you need in your shed? Much more than a bit of lighting and you need mains (or spending a lot on renewable energy kit for no viable return).
Posted : 09/07/2013 4:23 am
Solar panels seem to be fitted to just about every canal boat I pass on my commute. I guess the set up would be similar to on a shed, so a canal forum may be a better place for info.
http://midsummerenergy.co.uk/solar-panel-information/Guides/ShedsBarnsAndGarages
Posted : 09/07/2013 8:25 am
I built my own system in the end - bought a 12V solar panel, a charge controller for a street light and a 12V SLA battery with suitable capacity for my needs from EBay. Solar panel sits on the roof, the charger controller is a doddle to connect (6 connections to the panel, battery and load device, a light in this case) - happily runs the light in the shed, an AA/AAA battery charger, radio, mobile charger etc etc though voltage droppers, again from Ebay for a few quid each.
Posted : 09/07/2013 8:28 am
The solar centre do complete kits and sell the batteries and converters for running stuff in your shed.
Posted : 09/07/2013 9:03 am
