Shadow to bottom ha...
[Closed] Shadow to bottom half of TV screen, solution?
Finally sat down after a busy weekend at work, only to find the TV is playing up. A dark shadow has appeared across the bottom half of the screen. I can see the picture it's just annoyingly darker than the top half.
Tried factory reset, latest software update etc but no improvement.
So is it knackered? Anyone else had a similar issue?
Posted : 29/05/2017 9:58 pm
Depending on how dark it is, it sounds like the rear illumination (can't remember the correct term for it) has failed.
Not an expert though, so hopefully it'll be something a little less terminal!
Posted : 29/05/2017 10:03 pm
Assuming it's not an LED set, it sounds like a duff backlight.
Which may be difficult to sort without a soldering iron and some replacement parts.
Posted : 30/05/2017 8:05 am
"Looks like we'll need a new telly dear"
...the sort of failure every bloke looks forward to! ๐Ÿ˜€
Posted : 30/05/2017 8:12 am
In the old days of cathode ray tubes this meant somebody had gone near the screen with a powerful magnet and you needed to get the repair bloke out with a degausser.
No idea whether this applies to these modern flat TVs though.
Posted : 30/05/2017 8:57 am
 ji
Before throwing it out, try a different cable and /or source (DVD etc) to check the fault is actually with the TV.
Then buy a new one anyway!
Posted : 30/05/2017 10:30 am
