I’m trying to make some tubes to hold in an insulin pump on his leg for a friend and am having difficulty finding lycra fabric by the metre of the sort that would be used to make bike shorts. The first one I made for him I used an old pair of my shorts to get the piece I needed, but now I want to make a set for him from fabric cut from a roll.
I’ve bought a few samples from Tia Knight fabrics and had ordered some ‘heavy lycra’ off ebay but this hasn’t turned up. Not convinced that any of the samples I've tried are right as they have too much stretch
Does anyone know what the fabric is called (other than lycra?) - I need some that has enough stretch to accommodate the pump but not so much that it will lose its shape.
Any ideas where I can get this stuff from?
Something like this - 190gsm? Or is that no thicker/heavier than the samples you've already had?
http://ukfabricsonline.com/sports-fabric/red-sportswear-nylon-lycra-fabric
I usually get it from eBay but the quality and type is pretty variable. Another option is stretch pvc which is tougher and stiffer but not breathable so that might be an issue. What about thin neoprene? Might be easier to go to a good local fabric shop and get your hands on it. Final idea, what about using lycra for the bulk of it then some stiffer fabric or extra stitches where you need it to hold shape.
You probably need [b]swimwear[/b] fabric, with 20% lycra (aka spandex or elastane), rather than sportswear/dancewear fabric with lower amounts of lycra.
Good ideas all, thanks very much. I'll start with ordering a sample of the stuff Fiona found then if that isn't right will try the other suggestions.
Thanks!
Perhaps talk to someone like physiotherapystore.com
[url=profabrics.co.uk]Point North[/url]
Might be able to help.
