Good morning.
At 7.15, that's about ten minutes time, we are moving the site to a new server. There should hopefully be little interruption BUT I will need disable posting to the forum for about ten minutes. If you post anything between 7.15 and my next post in this thread, it may never be seen again. Thanks. BRB
Thanks. All done for now.
didn't see the new search engine, that's for sure. ๐
In fact, I saw nothing. Do you think that's significant?
There are significantly fewer comments about hamsters.
I didn't see any hamsters either. Have you upgraded to a wind turbine? I've heard they're very reliable ๐
i saw a puddy cat, need to check if it's creeping up on me
Don't believe the old search is going to come back - if it was it would have happened by now. Very very disappointing.
That's not particularly right. The old search used MyISAM and fulltext which was causing some unacceptable table locks when searching through a million posts. We're working on a replication solution to get around it, but it's going to take a little time and other resources to implement.
Cool. That would be good.
Not feeling 100% today so being grumpy on a number of posts ๐ณ
