Seized Murker Futur...
[Closed] Seized Murker Future Razor
Due to a lack of maintenance and a year or so not using it a while back, my adjustable razor has seized so I cannot vary the setting or disassemble it ๐Ÿ™ย  To be honest, I didn't realise you could take them apart, I also didn't really register that it had seized as with soapy hands there is no grip on the handle.
So far I have soaked it in a 50:50 water vinegar solution for 30 minutes, WD40'd it, dunked it in boiling water, 48 hours soaking in plusgas, some tentative taps on the workbench, and giving it a few warning shows with a rubber mallet.
The adjustable section of the head appears to have a little movement so I'm pretty sure its the threads that are corroded, does anyone have any other ideas to get it open?ย  I could go for neat vinegar but I know someone else stripped all the gold plating off theirs, mine is the silver satin finish.
On the plus side, its the cleanest the thing has ever looked!
Posted : 20/11/2018 7:34 am
bump!
Posted : 20/11/2018 6:58 pm
My murker did similar to this, it was the circlip it has extended some how. Prising the blade holder up did the trick but it now can only bet set a minimum setting.
Posted : 20/11/2018 7:23 pm
So, you broke it?
Posted : 20/11/2018 8:03 pm
Mine is on setting 3 but the blade holder appears to be in the lowest position...
Posted : 20/11/2018 8:50 pm
It looks like a poor quality razor compare to the Gillette fatboy that I have even when it is made in the 50s.
When I got it I just cleaned it up like you do with your Merkur and everything works.
Posted : 20/11/2018 9:09 pm
