Screwdriver turns l...
[Closed] Screwdriver turns long V short ?
More turns with a short screwdriver?
Less turns with a long screwdriver?
The same amount of turns ?
I give up !
Posted : 17/10/2018 8:49 pm
Three pumps with an 18” Yankee should do it.
Posted : 17/10/2018 8:52 pm
Fewer turns with a long screwdriver?
Posted : 17/10/2018 8:53 pm
If we’re talking about the cocktail, i’d suggest you put the bottle down..
Posted : 17/10/2018 8:58 pm
can someone mansplain why a longer  screwdriver appears to increase torque?
Shirly the twisting movement is dependant on muscles and tendons , but .- a longer one seems to  give moar ooomph
Posted : 17/10/2018 9:07 pm
Easier to get a long screwdriver set straight in the screwhead. Having the screwdriver slightly off straight gives the effect of a wider turning circle compared to a short one being way off straight to achieve a similar advantage.
Posted : 17/10/2018 10:08 pm
Confirmation bias?
Posted : 17/10/2018 10:14 pm
Imagine a cone with the point at the screwhead. For a given angle a longer screwdriver will have a bigger top to the cone which is the effective lever that you are using to undo the screw. There’s a limit to the angle before the screwdriver will slip so a longer handle is the most effective way to apply more torque.
Posted : 17/10/2018 10:37 pm
parkesie has it - its a lever thing , stubby screwdrivers although needed for access sometimes are horrible to use.
Posted : 17/10/2018 10:43 pm
Image result for science bitch
Posted : 17/10/2018 10:56 pm
Surely once the thread bites it will be drawn in to the hilt by exactly the same number of turns on the helix whether you use a long or a short screwdriver. A nut doesn't screw down onto a bolt faster with a long spanner compared to a short one. It makes the same number of turns regardless.
Posted : 17/10/2018 11:33 pm
Perchy got it in one. Why would you use anything else?
Posted : 18/10/2018 12:29 am
