Scrambled Eggs
Scrambled Eggs
Do you believe the use of a microwave is to the detriment of the final result.
Do you agree butter and saucepan is the only way to go?
Posted : 27/05/2023 8:33 am
Yes. Streetfood style...
Posted : 27/05/2023 8:37 am
Microwave is method of last resort. The fat and water seems to leak out leaving dry egg sat in a greasy puddle.
Should also add some milk or cream, salt and pepper....
pondo reacted
Loads of butter in a pan on the cooker, seasoning and don't over cook it!
I occasionally add some garlic soft cheese for some extra oo la la!
Posted : 27/05/2023 8:42 am
geck0 reacted
Good eggs, good butter, we’ll seasoned in a good heavy pan. Stop just before you think they’re done.
Simple things done well.
Posted : 27/05/2023 8:46 am
leffeboy and fasthaggis reacted
Never done scrambled in microwave so would be interested to hear how they're done. Have done what l call microwave mini omelettes loads. They are definitely lesser to using a pan, but good enough for quickness.
Method:
Two eggs in microwavable breakfast bowl, add dash of milk then whisk until all well mixed. Add a small knob of butter.
Microwave for 12 seconds, remove and give quick whisk to mix in butter. Microwave for further 1 min 25 secs.
Season and serve on toast of choice. Above timings may have to be tweaked for each Microwave as cooking too long results in rubber. Can also add extras at start such as cheese and ham.
Posted : 27/05/2023 9:05 am
Lots of butter, cook slowly, take off the heat just before they're done. You don't need milk.
Posted : 27/05/2023 9:13 am
Certain foods should be kept away from a microwave and scrambled eggs need to be cooked slowly on the hob, where possible.
Posted : 27/05/2023 9:23 am
J-R reacted
 poly
Merak - yes the finished product is worse.  pan is not the only way to go but is the best result.  A very patient person can make ok scrambled eggs in M/W - melt butter first (which also pre warms bowl) stir in the eggs and take in and out the M/W lots more than you think you should - every 5-10s and stirring constantly for the same length of time (5-10s) between returning.  It still won’t be as good as well cooked eggs on the hob but will be better than badly cooked eggs on the hob.  Most people overcook the eggs whether on the hob or m/w because they don’t appreciate they will continue to cook once you turn it off. IMO melting the butter first is essential as its water content is low so doesn’t absorbs M/W well therefore you actually cook the eggs before the butter is properly melted otherwise.
heston developed an interesting method for scrambled eggs for Little Chef a while back as they had no decent way…. It was in a pouch in a waterbath - if I worked in an office with no hob or microwave I’d be tempted to see if a kettle of boiling water in a big bowl could achieve the same thing.
Posted : 27/05/2023 9:35 am
As above, I do mine in a pan. 3 eggs, salted, into a hot pan with oil and butter and caresses around the pan for about 30 seconds. Pepper added at the end.
Posted : 27/05/2023 9:45 am
Do you believe...
Do you agree....
This sounds like an ongoing argument. 🙂
Posted : 27/05/2023 9:49 am
In pan add kimchi at the end is delicious.
Eggs, pepper, bit of cheese in a cup, lump of butter melted in a pan, cup contents pored in and then stirred until they look nearly done.
End.
Posted : 27/05/2023 9:56 am
add kimchi at the end/blockquote>
Reported
Posted : 27/05/2023 10:15 am
eggs, butter salt, pepper.
low heat, cook until soft peaks appear.
anything else doesn't work
Posted : 27/05/2023 10:21 am
susepic reacted
Surely it depends on how "wet" or fluffy you like your eggs?
Posted : 27/05/2023 10:24 am
 tomd
Their are basically 2 acceptable versions of scrambled eggs:
1) French - eggs are stirred continually and gently heated until fluffy and creamy. A dash of cream at the end to stop cooking
2) American - bit of butter and eggs are lightly fried with some stirring to give larger curds and some extra flavour from browning
With very careful microwaving (low power, lots of stopping to stir) it's possible to do an ok version of #1. But you could do it quicker and better in a pan so really only for when there's no hob.
Growing up we had nasty scrambled eggs with milk added so the liquid leached out after cooking. I think the milk adding was something my parents picked up from theirs, who started it during rationing to make the eggs go further. It's an abomination.
Posted : 27/05/2023 10:27 am
 kilo
Melt the butter in a pan and then gently cook chilli flakes for twenty seconds or so before adding the eggs.
When cooked and served add green Tabasco as desired.
Posted : 27/05/2023 10:39 am
Smallest burner, lowest setting, for as long as it takes, stirring almost all the time
No milk.
Chopped parsley and a shot of tabasco in the mixture
Chopped smoked salmon or al dente asparagus tips stirred in a minute before it comes off the heat
Posted : 27/05/2023 10:50 am
 Del
1:20s for three large eggs in my microwave. If unsure back off time and do 5s min, 10s max bursts. 5s is min required in my microwave to effect any change of state. Salt, pepper, nothing else required. Consistently good results.
Posted : 27/05/2023 11:16 am
Lots of butter, cook slowly, take off the heat just before they’re done.
This is the way.
Then also stir a spoonful of double cream through right at the end.
Posted : 27/05/2023 11:28 am
Yes.
Posted : 27/05/2023 1:14 pm
3Eggs, no butter,couple of teaspoons worth of milk, tiniest pinch of good salt. Cook until runny.
Posted : 27/05/2023 2:03 pm
Everyone has their own view but for me: garlic oil spray, black pepper. Avoid the microwave as it'll turn it into a school dinner.
Timely, as I'm just back from a 6 hour ride and making one now.
Posted : 27/05/2023 3:11 pm
I'm happy enough with microwaved eggs, too much else to be doing with my life to be messing about.
"Creamy" ie. still liquid eggs give me the boak.
Posted : 27/05/2023 4:56 pm
3 eggs per person, Knob of butter, splash of milk, plenty of white pepper and a saucepan on gas. Cook until just firm
Posted : 27/05/2023 5:08 pm
 J-R
Just watched my sister making an “omelette” following the microwave scrambled egg method.
No “believe” about it.
The thing that comes out is like the eggy substance that used to be served in aeroplane breakfasts in the days when airlines actually provided hot meals on short haul. It is almost, but not quite, entirely unlike scrambled egg or omelette.
Make it if you want, but don’t call it scrambled egg.
Posted : 27/05/2023 5:09 pm
I use Gordon's method, a couple of eggs, a few knobs of butter added, whisk, add salt and white pepper ( much more suited than black), cook low and slow, keep stirring, I sometimes add a bit of parmesan at the end.
Posted : 27/05/2023 7:17 pm
Kuco reacted
you need cheese to make scrambled egg.
dont let it boil,turn it down and let it dry out a bit
Posted : 27/05/2023 8:31 pm
You need butter / cream / cheese to make your scrambled eggs edible, and then have the audacity to complain about people microwaving them?
Posted : 27/05/2023 9:01 pm
theotherjonv and susepic reacted
You definitely need butter, plenty of it. But certainly not cheese or milk or cream. Cook over a VERY low heat until barely set.
Posted : 27/05/2023 10:37 pm
J-R and susepic reacted
You can do scrambled eggs using a steam jet. It is quicker, and I've used it in kitchens I've worked in, though only for staff meals rather than the restaurant.
If you go to a cafe and order scrambled eggs,listen out for a steam jet
Posted : 27/05/2023 11:20 pm
@catfood +1
Posted : 27/05/2023 11:49 pm
Interesting about the water, I once saw an audition for a cookery show where the test was to make the best scrambled eggs. One young kid surprised the producers and pro chef by using a bain marie , he said his grandma showed him how, he won while all the rest made rubbery piles !
Posted : 28/05/2023 4:08 pm
3 eggs per person wtaf! no wonder they are rationing eggs.
Posted : 28/05/2023 4:22 pm
Forget the scrambled eggs, what to do with those tossed salads?
Posted : 28/05/2023 4:50 pm
 Del
Just because your sister is shit at using a microwave doesn't mean someone else can't do it.
Posted : 28/05/2023 6:14 pm
 J-R
Just because your sister is shit at using a microwave doesn’t mean someone else can’t do it.
Just because my sister’s shit at cooking eggs in a microwave doesn’t mean someone else will do it well.
Posted : 28/05/2023 6:28 pm
Microwave is a lazy but acceptable method if you're in a rush or catering for several people.
Winner in our house is to chunk up an inch or so of chorizo sausage, fry that off in the pan so it covers the pan in is oil, then crack two eggs straight in and mush them up with the spatula.
Posted : 28/05/2023 6:59 pm
Should also add some milk or cream, butter, salt and pepper, cheese, maybe some soy sauce, chilli flakes, maybe some finely chopped smoked salmon…
Works for me. Note to self - need eggs.
Posted : 29/05/2023 12:05 am
Microwave? No. Unless you want spongy egg.
Best method has been described a few times: low heat, pan, butter, salt, pepper, eggs, stir, stop when still runny so they are moist on the plate.
this is a sous vide method. It is great for larger quantities or when you have time. Otherwise a faff compared with a pan. https://recipes.anovaculinary.com/recipe/heston-s-sous-vide-scrambled-eggs
Posted : 30/05/2023 7:49 am
no butter or oil. Non stick pan on low heat. Keep stirring. Take off the heat as soon as they stop being runny ( theyll keep cooking in the pan). Serve on buttered brown or sourdough toast. Splash of ketchup. Magic.
Posted : 30/05/2023 8:21 am
WHAT? Also milk - why?
Eggs, seasoning > melted butter > cook slow til firm but sloppy > take off heat > add more butter to stop the cooking. Done.
Posted : 30/05/2023 9:33 am
no butter or oil.
What?!!! There has to be butter.
Posted : 30/05/2023 11:47 am
I have to disagree, what there has to be is the leftovers fat/oil from the bacon you've just cooked . . . and now I know what I'm having for lunch today
Posted : 30/05/2023 11:49 am
