We are wanting to fit a small TV in our kitchen/diner and I was planning on taking a feed from our Sky box around the house and into the new set but it just occurred to me - our satellite dish is directly above the place we would put the new set.
So the question is - can I take a feed directly from the dish and into the TV (assuming I get a TV with built-in Freeview of course)? The dish has a quad LNB with one feed free.
M
you'd need built in freesat [not freeview]
Ahh yes - good point. But if it was built-in I could do it easily then?
yes - straight connection in
Cheers 🙂
I'd be tempted to buy a cheap freesat box [~£30] & stick it somewhere unobtrusive & run AV cables to the TV
You may struggle to find a small TV with freesat built in but I'm a bit out of touch now so maybe you can
I'd be tempted to buy a cheap freesat box [~£30] & stick it somewhere unobtrusive & run AV cables to the TVYou may struggle to find a small TV with freesat built in but I'm a bit out of touch now so maybe you can
It is to go on a wall above work surfaces and near a sink etc so no room for a box unfortunately (and I want to keep wires etc to a minimum).
32" is the smallest freesat TV I've seen. Most freesat boxes are small enough to stick to the back of a 19" TV though.
