RTA - bridge max we...
[Closed] RTA - bridge max weights - 3300 kg motorhome tonnes, tons(long, short UK) help
Hi
Motorhome Maximum Technically Permissable Laden Mass (MTPLM) = 3300KG
as far as I can work out - it would not be legal to cross a bridge marked with a 3 ton max weight limit
because
- law relates to plated weight of vehicle not actual weight
- bridge figures are in UK aka long tons
- 3300KG = 3UK tons 555.25lb = 3.248 UK tons
sound right to you ?
thanks
Posted : 29/05/2014 9:24 am
Can we have that in English now please?
Posted : 29/05/2014 9:26 am
Imperial Ton is just over 1,000kg it's about 1,015kg for easy maths so 3,045kg so yes 3300Kg is over the limit.
Posted : 29/05/2014 9:36 am
Remember, if your wheels aren't touching the floor, you don't weigh anythng! So, JUMP those pesky low rated bridges Dukes of Hazard stylee...... ๐Ÿ˜‰
Posted : 29/05/2014 12:14 pm
Do you also question the maximum height signs? Perhaps you could convert between metric and imperial to squeeze under those.
Silly question surely? 3.248>3
Posted : 29/05/2014 12:18 pm
3000kg weight limit on Marlow bridge resulted in police clamp down the other month
An operation last month split opinion, proving controversial because of the fact that a number of Range Rover style cars were asked to turn around. Sixteen commercial vehicles were given ยฃ50 penalties on that day.
Posted : 29/05/2014 12:32 pm
I think the point being suggested here is that they're not as comparable as they seem. Height restrictions go on how high a vehicle [i]is[/i]. Weight restrictions go on how heavy a vehicle [i]can be[/i], regardless of what it is currently.
Posted : 29/05/2014 12:40 pm
Oh, fair point. Apologies.
Posted : 30/05/2014 6:27 pm
