Roof bar compatibil...
Roof bar compatibility question (Thule/Halfords)
6 Users
2 Reactions
I've got a set of Thule Wingbars on my car. They're super. They're 150cm width (it's a wide car).
I want to stick 'em on my dad's car for a trip (probably occasional trips). He has a wee Skoda which needs 118cm bars.
I figure I could stick them on as is, but there'll be quite a bit of overhang. So I'm looking at picking up a set of cheap Halfords bars for when we need them (the footpack is the same so that'll just transfer across).
Will this work? Are the different brands compatible?
Posted : 11/05/2024 5:12 pm
Edit...read the original post properly before typing not after 😄
Since the feet are compatible and assuming enough adjustment I'd just use the 150s unless the car is narrower than that overall.
I think my SMax uses about 120cm but the full car width is over 1.8m.  Most car roofs are a lot narrower than their width at ground level.
Posted : 11/05/2024 5:19 pm
16cm either side would be ok I reckon. Still less than wing mirror protrusion I'd think?
Posted : 11/05/2024 5:22 pm
I'd check that they fit first, I just got some 135cm Thule wingbars and there's not much more room for the feet to go further inboard, that's on a Fabia estate.
Posted : 11/05/2024 5:34 pm
Do check as there's limited width adjustment on most Thule bars.
The cheapest option is borrow some bars or look on faceache/gumtree to buy and resell- I've just been buying and selling bars and feet on there and most are £30-50 each.
Posted : 11/05/2024 5:37 pm
Are you sure?
Posted : 11/05/2024 5:47 pm
Yeah the footpack is definitely the same, they both have roof rails and I've checked on a couple of sites. I was slightly surprised tbh.
Good point about the limited adjustment, I think that'll stop me from using my bars.
I'll have a browse second hand and see what I can see! Halfords equivalents are 70 quid which is less than the price of hiring a bike...
Posted : 11/05/2024 5:56 pm
Where are you? I've 110 and 118cm bars you could borrow if you're near Dunblane.
Posted : 11/05/2024 6:30 pm
Cheers for the offer Matt, I'm in Hull so that might be a bit of a trek!
Think I've sourced some 130s from a mate which going by posts above should work nicely...
Posted : 11/05/2024 6:44 pm
