Ribbon Cable Connec...
[Closed] Ribbon Cable Connectors - Help!
I've got to copy an existing interface design for some equipment, which means taking a 128way (2X64) card-edge connector and manually soldering on 2 and 14 50ths of 50-way ribbon cable. Its a right ball-ache. There must be a better way.
Is there?
Posted : 17/09/2014 2:20 pm
Solder the entire length of the ribbon then remove the solder in between the contacts with this:
http://www.maplin.co.uk/p/de-soldering-braid-15mm-width-n48fx
Posted : 17/09/2014 2:23 pm
Can't you get an IDC type connector?
Posted : 17/09/2014 5:37 pm
