Resistor colour cod...
Resistor colour coding
Trying make sense of this resistor colour coding.
I understand the principle and used to be able to read quite clearly, however these colours are difficult to ID.
These are on a strip marked as 1M.
But the colours as I see them don't add up?
Can anyone help this simpleton?
Posted : 05/07/2023 12:49 pm
1 Meg
https://resistorcolorcodecalc.com/ (5 band)
Posted : 05/07/2023 12:56 pm
1 Meg
So how do I tell which is the tolerance indicator?
Posted : 05/07/2023 1:03 pm
The tolerance band is suposed to be fatter. Mostly though, you can tell if reading the other way gives a weird value.
1M is a common value. 140R is not.
Posted : 05/07/2023 1:19 pm
kelvin reacted
Thanks for that.
I read that the tolerance band is supposed to have a bigger gap from the last band. However, the tolerance band in that picture is about the same distance.
Posted : 05/07/2023 1:26 pm
Sometimes the gap is larger, but this is inconsistent and can be quite difficult to distinguish for the 5-band resistors. The blue ones are also harder to read, perhaps because the colour contrast is not great.
If in doubt, I measure the resistance with a DMM.
Posted : 05/07/2023 2:41 pm
