Replacing ABS Senso...
[Closed] Replacing ABS Sensor on Ford Mondeo
 Jase
The ABS light on my mondeo started to come on after having a front spring replaced and after looking on the net it sounds like it could be due to a faulty sensor.
Looks like I can get one from ebay for around £11 but does anyone know if replacing is an easy job? Is it simply a case of unplugging the old one and replacing?
I’d imagine my main dealer will charge a fair bit so I’d like to do myself if at all possible.
Thanks
Jason.
Posted : 22/10/2013 3:22 pm
Pretty easy, remove the wheel. Look around the back of the disc and you'll see the cable going to a black plastic box. Unscrew out (torx I think?) and replace.
Posted : 22/10/2013 3:29 pm
 Jase
Great, must be worth a go.
Its due for a service in 2 weeks so will have a go just before, that way if I balls it up they can put right!
Thanks.
Posted : 22/10/2013 4:01 pm
