Replacement (or rep...
Replacement (or repair of) grill handle
 nbt
We've a Gorenje grill / oven with a removable wire handle on the grillpan. It recently split at the point where it's welded / tacked / joined, as per this image:
2024-11-28 19.20.02
I've got a soldering iron, but somehow I doubt that will be enough to fix this. I don't have access to a welder or any other metalwork equipment, but can ask around - the question is how would thie be fixed, or where would I find a replacement?
Posted : 11/12/2024 11:03 am
Measure the oven and get a new grill pan with the same dimensions?
Posted : 11/12/2024 11:16 am
If you've got no welder maybe a bit of steel wire, wrapped round a few times and then twisted with pliers to tension and fix (you could use solder to seal/fix it a bit if you wanted too). Won't be the prettiest but should work.
Posted : 11/12/2024 11:17 am
Use a tea towel to hold the grill pan.
Posted : 11/12/2024 11:26 am
thols2 and thols2 reacted
 nbt
If it comes to it then we'll do this but a fix or a new handle is perhaps the more eco-friendly option
Posted : 11/12/2024 11:29 am
This - I never use a grill handle. Also, I am sure there are universal handles available.
Posted : 11/12/2024 11:32 am
I would probably either wind with wire as suggested above, or get a small jubilee clip if you can get one small enough & use that to close up the gap.
It would at least do as a temporary fix.
Posted : 11/12/2024 11:42 am
Yeah, if you're not bothered about aesthetics, a small jubilee clip would do the job fine, I think. I have one here you can have for nowt if you're passing through.
Posted : 11/12/2024 11:58 am
Bunnyhop and Bunnyhop reacted
Or possibly this?
https://spares2repair.co.uk/handle-grill-pan-support-cr-gorenje
Posted : 11/12/2024 12:10 pm
 nbt
I've a box full of jubilee clips of varying sizes thanks. Will see how that suggestion is received
Thanks for the link to the "official" part, I think a new pan will be the choice if the jubilee clip is not deemed suitable
Posted : 11/12/2024 12:16 pm
We've got two unused grill pan handles (that are frankly just getting in the way), you can have one of them if you like. They're from a Stoves grill, but you're welcome to give them a go.
Posted : 11/12/2024 12:27 pm
Just had a quick look and yes, universal handles are available. Get one from Amazon and send it back if it doesn't work.
Posted : 11/12/2024 12:36 pm
Also, how about using Sugru for a fix?
Posted : 11/12/2024 12:53 pm
 toby
Do you not know of a man in a shed who does small scale metal fabrication in your local area? That looks like the sort of job where a spot of TIG weld woud be a moment's work and happily swapped for a packet of biscuits...
Posted : 11/12/2024 1:05 pm
That looks to be right on the edge of heat tolerance.
I have a similar question that I've been meaning to post, only it's the grill pan rail which is coming loose. Getting to the back of it inside the cooker looks to be a massive job, if there's a temperature-proof equivalent of that scoobydoo stuff then I'm all ears.
Posted : 11/12/2024 1:39 pm
Wrap in copper wire solder.
Posted : 11/12/2024 1:42 pm
scoobydoo
You get high temp JB weld putty i think.
Posted : 11/12/2024 1:43 pm
I wouldn't have thought so – the join is quite close to where you hold it and therefore shouldn't get too hot. Anyway, it was just an alternative suggestion – I think wrapping in wire is the best solution – do both sides and make them nice and tidy wraps and it would look like a deliberate design accent.
Posted : 11/12/2024 1:58 pm
Or metal cable ties. I must admit that I have never come across these before – I wish they existed (or I had known of their existence) 35 years ago when I was trying to hold together my fast-dissolving Mini 1275GT.
Posted : 11/12/2024 2:05 pm
Is there no scope for using a spoon? ;0)
Posted : 11/12/2024 2:31 pm
IHN and IHN reacted
 nbt
used a jubilee clip. All good
Posted : 11/12/2024 7:53 pm
