Repair to Event - h...
[Closed] Repair to Event - how?
 Joe
Burnt a a hole about the size of two pin heads in a new event bivvy bag. I am a proponent of tumble drying event to renew the DWR on it and so am suspicious of patches that are self adhesive.
Cany anyone suggest a more permanent fix? Will seam grip bridge the hole?
Posted : 17/02/2021 7:08 pm
I've used stick-on goretex patches on Event fabric before and it was permanent- no problems with tumble drying. That was a waterproof jacket with a 2.5 or 3 layer Event though, not sure if it'll be identical.
Posted : 17/02/2021 7:48 pm
You can buy the stuff they seal the seams with.
https://www.ebay.co.uk/itm/HQ-20mm-28mm-Textile-Repair-Tape-Seam-Sealing-Waterproof-Jacket-Patch-Gear-Pants/402528051181
It's hot melt, but it's the same as your jacket is already sealed with - at least, the stuff I have is, I can't tell from the picture if that link is the same. I've used it loads, it's brilliant - and it needs a lot of iron heat to get it melted so a tumble drier isn't going to melt it.
Also, don't tumble dry your jacket - air dry then iron it. I think tumble drying wears off a lot of the Nikwax straight away. And I think the instructions on my eVent jacket do say not to tumble dry.
Posted : 17/02/2021 8:17 pm
