Community
Render cracking beh...
[Closed] Render cracking behind stove
Hello had woodburner fitted for last 2 years render at the rear of it (the back wall of fireplace)is cracking and beginning to come away.is it possible to get a metal plate which covers the back wall of the fireplace?.if so any recommendations?.happy to have a go myself instead of paying someone.i think if it gets rendered again it will eventually start to come away agai.cheers.
Posted : 16/12/2014 3:12 pm
Just use a heat resistant board and paint it out. Will look the same as render.
Posted : 16/12/2014 6:04 pm
My partner has a huge sheet of stainless behind her fire - looks ace with the rest of the decor. It was quite expensive and that was almost a decade ago; can't remember off the top of my head.
The fire board stuff Wrightyson mentions is a lot cheaper and is available in various finishes. Well, it was the last time I looked.
Posted : 16/12/2014 6:16 pm
Remove the render and line it with 12mm Hardiebacker, decent tile shops should stock it.
Posted : 16/12/2014 9:31 pm
No idea what stove but I know Charnwood does a rear heat shield option for a lot of their stoves your stove manufacturer might do one too
Posted : 16/12/2014 9:38 pm
Does your flue come out of the back or out of the top of your stove?
If it's the back I'd get a 4-7mm steel plate made (around £20-£40) cut a flue sized hole in it and it should be fine.
If it's the top then get some vermiculite board to dot n dab on the wall behind the stove. It's heat resistant, it'll probs need painted though.
Posted : 16/12/2014 9:44 pm
I used steel sheet painted with heat-resistant paint over rockwool. The multi-layer insulation starts at the distance flammable materials are allowed and is normally covered with wood. The radiator behind the stove recovers a bit of heat for the bathroom, it thermo-syphons but the pump speeds circulation.
Posted : 16/12/2014 10:01 pm
I used a piece of 6mm steel behind my stove painted black, as I was worried about anything else I could put up cracking.
My other stove has Hardie backer behind it and it has cracked, though I did use a thunder bolt in the middle to hold it to the wall. That was probably a mistake.
Posted : 16/12/2014 10:42 pm
Is it just me who read the title and thought it was about Rudolph?
Posted : 16/12/2014 10:57 pm
Ours has cracked after just over a year. We're going to replace with some mosaic tiles.
Posted : 16/12/2014 11:19 pm
Looks like Edukator is squatting in Worldclassaccident's shag palace... 🙂
Posted : 17/12/2014 9:13 am
True, the house does resemble an over-sized sauna.
Posted : 17/12/2014 12:35 pm
