[Closed] Removing mastic from tile joints
Hi all
What's the best way of removing mastic from tile joints, has become discoloured, will replace with waterproof grout
Rake it out or use some form of solvent
Posted : 24/11/2014 8:57 am
You can get sealent remover from most DIY stores and it works pretty well. Squeeze it on, leave it for a couple of hours and scrape off.
Posted : 24/11/2014 10:39 am
Silicone remover to get rid but I would replace with decent bathroom silicone like Dow Corning 675 and not grout, tile joins need to be able to move or you will get cracking.
Posted : 24/11/2014 11:01 am
WD40 is your friend and a lot cheaper than sealent remover, doesn't take long either. Try it.
Posted : 24/11/2014 11:54 am
