I've decided I need to get a towbar fitted to my car for use with a bike rack.
I don't really want the towbar on my car though so I've been looking at removable ones where the frame has a sort of socket with latch on it and the swan neck can be unlatched and removed without the use of tools.
It occurs to me though that any play in the interface, while not being an issue if used to tow a trailer, could be a problem with a bike rack cantilevered off it.
Anyone got any experience of this type of towbar?
Got a Thule removable swan neck on the Pug and never had any problems with it when using my 4 bike rack.
Seems just as sturdy as my previous flange mounted towbar & rack. Been using it for over 3 years so far with no issues.
Westfalia removable swan neck on my van used with a Thule rack. Had no issues with it or with anything else I've towed, caravan, car & box trailers.
Got one on my new (2nd hand) car. No play on the ball, and a bit of a pig to remove (possibly due to muck and not being taken off for a few years).
not an issue when you use it properly (within the weight limit)
been using a Witter removable bar with an Atera rack like below for four years and no issues
I've had a couple of westfallia removable swan neck tow bars, fitted to different cars and found them to be really good.
Always found PF Jones had the best price, and have used local fitters.
It's a bit of an upfront investment to have one fitted and then buy a carrier also, I use a Thule 2 bike carrier, but I reckon for the convenience you can't beat it.
Tow bar and bike carrier can be fitted in about 1 minute.
Saves the hassle of a dirty bike in the car, or on the roof.
i used PF Jones also
I had a pendle rack before with a flange mounted bracket on a previous car and although I appreciated the secureness of the slot in system, the rack itself was a pain in the arse. Heavy, cumbersome and you had to piss about underneath with alley screws to adjust anything. Even the uprights couldnt be collapsed without using an allen key. Awful thing.
So, I've bought a second hand Thule 9402 and now just need the towbar.
Same here on my van, spot on
If it's only for a bike rack and not for towing, get the Thule bike rack adapter instead of a towbar. Works better.
molgrips - Member
got a link? I can't seem to find any details on that.
I have a Westfalua detachable too. No noticeable movement when a bike rack is fitted on it. When it is removed you can't tell the car had a towbar fitted. Mine also came from PF Jones.
