Reliable stud/ wire...
[Closed] Reliable stud/ wire detector?
Is there actually one that does the job well?
Posted : 22/03/2013 8:39 pm
I've tried about every sensor on the market and the best I have found is a Prosensor 710 from Franklin Industries. I don't know if is readily available in the UK (I'm in the US), but sure you can get it online (that's how I got mine as the hardware stores and big-box home improvement stores didn't have it). Not cheap, but excellent results.
Posted : 22/03/2013 9:04 pm
Electric drill with a masonary bit !!
Posted : 22/03/2013 9:05 pm
Non pick up plastic water pipes.
Oh and if the customer tells you there definately isnt a pipe buried in the wall and its ok to drill, DONT.
Alos beaware of pipes,cables behinf arcitraves and skirting.
Posted : 22/03/2013 9:08 pm
 Bear
An apprentice.
Posted : 22/03/2013 9:10 pm
My jab saw picks up anything except plain plasterboard...... Want to borrow ?
Got a Bosch one. Wasn't cheap but seems work well. Only thing it is poor at it picking up joists through lathe and plaster
Posted : 22/03/2013 9:13 pm
Yep I seem to find the little buggers with my drill as well!
I will have a look at the Prosensor and Bosch ones, cheers fellas!
Posted : 22/03/2013 9:21 pm
