regular knock/thud ...
[Closed] regular knock/thud in house
I've just started hearing a regular thud/knocking sound somewhere in my house. It's too metronomic to be animals/humans doing whatever - should I call a plumber? It's really hard to locate and seems to move. It's not 24/7 either.
Dodgy plumbing? (First time in several years Ive experienced this).
Walls expanding/contracting in this hear (previous owners had insulation piped in).
Posted : 07/06/2016 11:57 am
Ghost?
[url= http://singletrackworld.com/forum/topic/my-daughter-sees-ghosts ]Did you see a paint tin?[/url]
Posted : 07/06/2016 11:58 am
Mine does this after I flush the toilet once the cistern fills up. I guess its loose pipes or something knocking when the pressure increases when the water turns off.
Posted : 07/06/2016 12:12 pm
That's water hammer (or surge, or may other names), basically the water in the pipe has momentum, so when the valve closes suddenly it hits the valve with a thud as the energy is dissipated. On long pipes it can be quite a lot of energy so things like unsupported corners get a bit of a jolt.
So it could possibly be a tank in the loft or a cistern opening and closing (and if its at random rather than a short time after you've used water elsewhere it means something somewhere is leaking).
Posted : 07/06/2016 1:05 pm
Ours does this every night and every morning. We reckon it's something to do with the boiler. We found the boiler is doing something and when it stops there's a thud. Maybe it's the pressure moving pipes?
Posted : 07/06/2016 1:13 pm
Just had this; it took me a few maddening weeks to solve the mystery. I went and sat by the water meter and could see that water was flowing very slowly prior to the thump so I knew something was leaking. Went to the attic and fiddled with the ballcocks (ooh Matron!) but couldn't reproduce the sound. Our downstairs bog has a Geberit concealed cistern, which overflows into the bowl not out of the house. The knock seemed to be coming from there but I couldn't see water until I held a piece of bog paper against the back of the pan and it got wet; the trickle of water was invisible in the bright light. The water level was dropping and the fill valve opening momentarily then closing with a chuff and a thump.
I removed the flush mechanism, which is easy with a Geberit cistern and found that the soft polymer washer that holds back the flush had water blisters in it; Googling confirmed that this is common and the temporary cure is to prick the blisters with a pin. New washer and problem solved.
Posted : 07/06/2016 1:16 pm
It's the motorised valve that controls your hot water or your heating; the synchronous motor moves an arm, which moves a hard rubber ball to close the port, sometimes causing water hammer. Our Y plan valve was doing it so I replaced it and the noise was no better so I wrote to Honeywell, who replied with a long rambling explanation that if you don't install the valve with a minimum of six inches of straight pipework each side of it, laminar flow in the water coming from a bend in the pipe has been found to cause the thump. So that was me told, then.
Posted : 07/06/2016 1:30 pm
That makes sense! My dad helped install it many moons ago.
It got worse when we go a new boiler a few years ago. Presumably because it was more powerful it became worse.
Posted : 07/06/2016 1:45 pm
