Community
Reducing bit rate i...
[Closed] Reducing bit rate in iTunes
I have downloaded some songs into iTunes but they are quite a high bit rate and I am wanting to reduce their file size so I can put them on my phone.
I realise this will reduce the quality of music somewhat but i'm prepared for that.
I am running iTunes 9 and in old versions of iTunes you used to be able to click 'Advanced - Convert to MP3' and it would re-rip them at your predetermined bitrate but 9 does not have this option, it has 'Convert to AAC' but I want MP3 format.
As I downloaded these songs I cannot re-import them at the lower rate.
Anyone got any tips? Do I need another programme to do this?
Posted : 16/06/2010 3:04 pm
in preferences change format to MP3 and bitrate to whatever you want. It's under "Import CD" or something
Posted : 16/06/2010 3:05 pm
retro83 - i found that but that only refers to when importing from a CD, but i've downloaded the songs and they are already in iTunes.
Posted : 16/06/2010 3:07 pm
really? I thought that set the format used for converting existing files also. My mistake.
Posted : 16/06/2010 3:15 pm
If its for an iPhone, there is an option to lower bitrate to 192 or 128 (cant remember) for all songs transferred to the iPhone. I think if you click on your iphone in iTunes, its one of the options where you've got copy contacts/notes to outlook etc.
Posted : 16/06/2010 3:26 pm
 MSP
copy the music folder to another location.
delete songs from itunes
re-import at lower bit rate.
I wouldn't do it myself, I would rather just put what I can on my phone for now, you will probably upgrade to a phone with more memory sooner or later.
Posted : 16/06/2010 3:30 pm
retro83 - I'll try it tonight but it might mean I have to copy files into another folder then recopy them into the iTunes library using the new lower rate. might work, i'll give it a go and see.
Milkie - not for iPhone, it's for Sony Ericsson phone.
Posted : 16/06/2010 3:31 pm
Select the songs then click on advanced from the menu bar and click Create AAC/MP3* Version
* will create a version using whatever the settings are in the import settings.
Posted : 16/06/2010 8:35 pm
Make sure you keep the original files. Useful for when you have a high quality system at home and when portable media players gain much more memory.
Posted : 16/06/2010 9:58 pm
You just select the file and go to Advanced > Create AAC/MP3 version
edit: as tomzo says, I think what I originally said does apply though
Posted : 16/06/2010 10:20 pm
