recording calls on ...
[Closed] recording calls on windows mobile
Want to record your mobile calls? Get bored with pressing the buildin record button every time you want to record on your mobile? WM Sound Recorder is an easy-to-use application which could auto record sound and phone calls in Windows Mobile Pocket PC. And it also can play the record file so that you can check if the record fits you. In addition, you may distribute your recorded files easily with it. Recording and playing audio on phone has never been so easy with WM Sound Recorder!
Free download here: http://www.wmsoundrecorder.com/download.html
The following is a step-by-step tutorial for operation.
Step 1: Download WM Sound Recorder here, unzip the file you downloaded and copy the installation file (sound_recorder_for_wm6.CAB) to your mobile device.
[I]Note that the software is working on the platform Window Mobile 5 and 6+.[/I]
Step 2: On your device, navigate to the location of the installation file using File Explorer, and click the file to start installation. You can install it either on your device or on the storage card.
Step 3: Click “Start” and select “Programs” after installation, you will find the WM Sound Recorder is already in your phone.
Learn to record calls and customize your recording
The following is the main window of WM Sound Recorder interface.
Step 4 : Click the "record" button (red) to record. As the "record" button turns blue, it starts recording. To stop recording, you can click the "record" button.
Step 5 :To listen to the recording file, you can click the "play" button, and to stop playing, you can click the "stop" button.
The above is the common functions of the software. Yet there are some important features of WM Screen Recorder to be explored.
Step 6: Click the “Action” at the bottom.
You can click “files” to make operations to the recorded files.
You can click “options” to set the Input format of the file as MP3 or WAV and their quality; or you can set the directory of your recording files. Besides, You can choose to record calls of next, today’s and all calls.
Note that the default setting is “Do not record any call”. ONLY you change the setting to other options (eg. Record next call) can your mobile phone automatically record your mobile phones.
[url= http://www.wmsoundrecorder.com/download.html ]Free Download[/url]or go to[url= http://www.wmsoundrecorder.com/index.html ] WM Sound Recorder Homepage[/url]to know more.
Posted : 12/04/2011 10:00 am
